07-22-2008, 21:09 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 820372 Status: Offline Thanks Meter: 0 | "Application has generated an exception ... " I just bought my Ultimate Sam but when I try to unlock my F490 I have this error message : I've tried with an other computer and it's the same. I've tried to uninstall/install again the soft and drivers but it's always the same problem. I use windows Vista. Can you help me please ? Thanks |
07-22-2008, 21:16 | #2 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 129308 Status: Offline Thanks Meter: 17 | yes i have the very same problem have turned of my firewall settings and everything else i can think of and am still getting the same problem.i also have tried on my xp laptop and i press unlock (trying to unlock a u700 phone is in qualcom mode) and it registers clip id..then a sighn flashes up from microsoft saying.............a problem has occured when trying to use ultimaye sam send report or not..you will have to shut down this feature now.or words to that effect.i even removed my avg im running to see if this would make a diffrence.sptfire my freind can you please help thankyou..getting frustrated now... |
07-23-2008, 07:48 | #3 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: Afghanistan; The Netherlands
Member: 261666 Status: Offline Sonork: 109.896 Thanks Meter: 780 | Quote:
Before trying to unlock, - put the phone in Qualcomm mode by *#782872# - attach the USB cable, PC will detect Qualcom USB....... if the drivers are not installed it will prompt "New Device found" - Point the driver wizzard to look into the C:/program files/Ultimate-sam Team/Ultimate-sam/Drivers/QualcommDrivers/ - Let the both ports be installed - Start the program and check again - if the problem is not solved yet, try to run USBDriver.exe from Drivers/folder unistall and resinstall the USB cable(prolific) drivers. hope this helps wbr spitfire | |
07-23-2008, 20:08 | #5 (permalink) | |
Member: 129308 Status: Offline Thanks Meter: 17 | Quote:
07-24-2008, 14:44 | #6 (permalink) | |
We are here to help, we dont ask any money for our time. wbr spitfire | |
07-24-2008, 19:01 | #7 (permalink) |
Member: 129308 Status: Offline Thanks Meter: 17 | ok thats great thankyou i have accepted you as a new contact and i will be on from 8pm uk time until 10 pm or so, i look forward to youre help and thxs for the great service i do appreciate it,please msn me ill have my volume up just incase im in my dining room with kids thxs again |
c261 after booting write " cpu Exception MSG " | saeid_gsm | Ultima Box Light | 1 | 11-20-2010 08:10 |
Why ustpro has not an usefull option like "reset security code"? | aikonmani | UST Pro II | 10 | 02-14-2009 09:59 |
Can someone Generate an SLD file? | zapatoca | Typhoon Dongle | 8 | 10-17-2007 23:24 |
+ Nokia has released an updated version of PC-Suite, v 6.7 (ex 6.6.18) | apocalypso | Nokia Multimedia | 2 | 12-08-2005 20:55 |
