Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultimate-Sam
Old 07-04-2007, 12:24   #16 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
Thanks Meter: 55
"This may take some time"
when the program displays this, it means the program is busy processing the data which is downloaded. It depends on your pc how quick it can process the data. If it takes more than 5 minutes and if it still doesn't do anything further, please try a diffrent pc and also read the FAQ & Troubleshooting.
After the file is processed, the lids will flash while the clip is being updated, but as long as the file is not processed yet, the lids can be either on or off. The clip must be ok, cuz I see that your clip's serial can be read by program.
Originally Posted by mobwort View Post
Getting the above message when trying to update. Taking absolutely ages!How long should it take roughly - can anyone help. Also should the clip be showing any sign of life while updating? Or do I have a problem here? Thanks.
Old 07-12-2007, 03:56   #17 (permalink)
Member: 38039
Thanks Meter: 6
Question Updating troubles, need help
hi, mate, nice to enjoy the forum supporting.
Now, i have some troubles on updating the clip, and need your help urgently.
I can guarantee that the cable driver and .net framework 2.0 are all well installed:
I can find a COM4 port added and two leds lighted after i plug in the cable; and the program can be launched.
The left i can do is pushing the UPDATE button, and waiting till updating is ok, but after searching COM1, COM2, COM4, the log always displays like this:
No Smart-sam Connected,. or the usb cable is not connected
need your help and suggestion, thanks.
Old 07-12-2007, 09:26   #18 (permalink)
sunnyc's Avatar
Member: 49495
Sonork: 100.9 & 100.12345
Thanks Meter: 1,026
Target not responding
Trying to reconnect
trying to set testmode
Flashmode enterd
ClipID=))))))
reading clip SW version
Version :v1.08
updating, please wait...
Trying to reconnect
Trying to reconnect
Could not update, please use another PC or contact your reseller
Old 07-12-2007, 09:40   #19 (permalink)
Registered User
Member: 19168
Thanks Meter: 55
The cable might not be fully placed in the clip, try to put it better. ifyou still have the same problem where it can't find the clip, it means your update cable is defective. try another one ifyou have or contact ur resller for a new one.
WBR
Old 07-12-2007, 09:44   #20 (permalink)
Registered User
Member: 19168
Thanks Meter: 55
Trying to reconnect
Flashmode enterd
ClipID=))))))
Version :v1.08
Trying to reconnect
Trying to reconnect
Which OS do you use? XP?
please try a diffrent cable or else another pc.
We are still busy on improving the updateUtility. It's still in it's beta steps.
Thank you for reporting with log.
WBR
to_deal_with
Old 07-12-2007, 16:02   #21 (permalink)
Member: 38039
Thanks Meter: 6
Question
WBR
hi, mate,
thanks for your quickly replying, really good support.
you say perhaps i've not plugged fully into the clip, why the two leds in the clip are all lighted when i plug the cable into the clip?
need your help, thanks.
Old 07-12-2007, 16:09   #22 (permalink)
Member: 38039
Thanks Meter: 6
Question
WBR
hi, mate,
Old 07-12-2007, 16:13   #23 (permalink)
Registered User
Member: 19168
Thanks Meter: 55
hi, mate,
it seems to be a cable problem then. Please contact your reseller for a working one. Or else if you wish to make the cable urself, pm me or spitfire.
Thank you
WBR
to_deal_with
Old 07-12-2007, 16:22   #24 (permalink)
Member: 38039
Thanks Meter: 6
Smile
Thank you
WBR
to_deal_with
mate, could you kindly give me some hints, maybe i can repair the cable by myself. The reseller and i are not in the same city.
thank you again.
Old 07-12-2007, 16:31   #25 (permalink)
Member: 38039
Thanks Meter: 6
hi, mate, i am waiting. thank you.
Old 07-12-2007, 18:16   #26 (permalink)
Member: 38039
Thanks Meter: 6
Question The cable is OK, the other question, need help!
hello, mate, now the cable is ok, and my clip can log in, but can't be updated, the log displayed like this:
Searching for Smart-Sam.. please wait
Searching on COM1
Searching on COM4
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Connected to Server
Reading sw version in server...:v1.09
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Trying to reconnect
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxxx
Version :v1.08
maybe i should be more patient?
Need your help and your solution. Thanks.
Old 07-12-2007, 20:14   #27 (permalink)
Registered User
Member: 19168
Thanks Meter: 55
Searching on COM1
Searching on COM4
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Connected to Server
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Trying to reconnect
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxxx
Version :v1.08
Please retry. if still the same problem, try to put another rj45 connector on the cable. and make the cable shorter between the converter and rj45.
wbr
Old 07-13-2007, 02:53   #28 (permalink)
Member: 38039
Thanks Meter: 6
wbr
mate, i don't understand your exact meaning.
i've tried many many times, it seems like that the updating is going into a dead loop unless the updating succeed.
and, the GUI of the updating application can't be refreshed again. (single-threaded routine?)
i don't know where is the other rj45 connector. there is ONLY ONE rj45 connector in the clip or in the cable (male or female). and, i think that the cable is too short to shorten. the rj45 output cable (from the PL2303 black box) is LESS THAN 20 centi-meter long.
need your other solution urgently, mate, thanks.
Old 07-13-2007, 02:56   #29 (permalink)
Member: 38039
Thanks Meter: 6
mate, i think that you'd pay more attentions to the updating
mate, i think that you'd pay more attentions to the updating.
Old 07-14-2007, 18:02   #30 (permalink)
Member: 38039
Thanks Meter: 6
mate, my customer and i are kept waiting for updating. Really really need your help.
can any one post here 5200 latest flash file .. makkah mobile Nokia Base Band 5 ( BB-5 ) 4 05-21-2007 20:28
Page generated in 0.25890 seconds with 10 queries
