Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultimate-Sam
Old 07-14-2007, 18:23   #31 (permalink)
Member: 38039
Thanks Meter: 6
Updating still failed, i am keeping trying, the log like this:
Searching for Smart-Sam.. please wait
Searching on COM1
Searching on COM4
Clip found on COM4
Flashmode enterd
ClipID=0xxxxxxx
reading clip SW version
Version :v1.08
Connected to Server
Reading sw version in server...:v1.09
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
This may take some time
trying to set testmode
updating, please wait...
Target not responding
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
Trying to reconnect
Flashmode enterd
ClipID=0xxxxxxx
Version :v1.08
CRC error aborting
Could not update, please use another PC or contact your reseller
PS., this is the 2nd PC of mine, the 1st PC can't even find out the CLIP.
waiting and keeping trying.
Old 07-16-2007, 02:24   #32 (permalink)
Member: 38039
Thanks Meter: 6
waiting for the updating solutions
Old 07-16-2007, 09:20   #33 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
Thanks Meter: 55
Hi there,
Please contact your reseller for a new update cable.
WBR
to_deal_with
Old 07-16-2007, 15:34   #34 (permalink)
Member: 38039
Thanks Meter: 6
Originally Posted by to_deal_with View Post
Hi there,
WBR
to_deal_with
mate, i've also tried another cable, always like this. I think that it's not the cable trouble. It can read out the CLIP id and others. I am patient and i'll still wait for the solution.
Old 07-16-2007, 21:56   #35 (permalink)
.:Spitfire:.'s Avatar
Member: 261666
Sonork: 109.896
Thanks Meter: 780
Hi mate,
I think the problem is inside the USB cable.
Solution
At the back of the PCB, you can see a resistor, please desolder it/remove it/.
Then try again.
If your problem still remains, contact me in private.
With best regards
spitfire
Old 07-18-2007, 02:03   #36 (permalink)
Member: 38039
Thanks Meter: 6
thank you, mate, i'll try and post the result.
Old 07-18-2007, 05:12   #37 (permalink)
Member: 188484
Thanks Meter: 117
HI.I have problem update ..Please tell me wath hapend ...com port available and ......
Old 07-18-2007, 07:45   #38 (permalink)
Member: 261666
Sonork: 109.896
Thanks Meter: 780
It means that the Updateutility could not communicate with your smart-sam. Please make sure you have the latest Prolific Usb drivers installed on your pc. http://www.smart-sam.net/driver/UsbDriver.exe reinstall the drivers.
Check if the LED's on your Smart-Sam Turn-on when you insert the cable into the usb port. (it will flash 3 or 4 times) if the LED remains off then you have install the latest drivers.
Post the results.
wbr
Spitfire
Old 07-19-2007, 02:14   #39 (permalink)
Member: 38039
Thanks Meter: 6
Unhappy After removing the 120oh resistor, also failed
Hello, mate:
I've removed the 120oh resistor of the cable, but the problem still exist. The log follows:
Searching on COM1
Searching on COM4
Clip found on COM4
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Connected to Server
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Target not responding, Retring please wait
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
It's not easy to be keeping patient. May my customers can accept the result.
Good luck, mate.
Old 07-19-2007, 09:08   #40 (permalink)
Member: 261666
Sonork: 109.896
Thanks Meter: 780
Hello, mate:
Searching on COM1
Searching on COM4
Clip found on COM4
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Connected to Server
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Good luck, mate.
Hello mate,
check this post.
Problems while updating, solved here!
with best regards
Spitfire
Old 07-20-2007, 07:36   #41 (permalink)
ssatcom's Avatar
Member: 17098
Thanks Meter: 51
Originally Posted by .:Spitfire:. View Post
Hello mate,
check this post.
with best regards
Spitfire
I maked this hardware also Problems NOT Solved
Searching on COM1
Searching on COM61
Searching on COM5
Clip found on COM5
Flashmode enterd
ClipID=xxxxxxxxx
Version :v1.08
Connected to Server
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Flashmode enterd
ClipID=xxxxxxxx
Version :v1.08
Old 07-20-2007, 14:01   #42 (permalink)
Member: 261666
Sonork: 109.896
Thanks Meter: 780
It is the GND problem which some may Face. Maybe the GND of the Clip do not make any connection with the metal casing,. Check if screw´s on the Clip is connected to GND of the Clip.
You may also try to hold the Clip in your hand while updating.
With best regards
Smart-Sam
Old 08-12-2007, 17:21   #43 (permalink)
Angello's Avatar
Member: 19927
Sonork: joe-lindien
Thanks Meter: 58
Hello,
I have one problem for update Clip.I have always "target not found".
I have tried with 2 computers Windows XP,and with 2 cables for update but no success.I'm sure my cable number one and PC number one working because my friend have update her clip and no problem.
I have solder GND to cover but have same problem "Target not found".
Could i send Clip to my reseller for change?
PS:Server read serial number and version of clip 1.08 but can't write into clip.
Old 08-14-2007, 21:02   #44 (permalink)
Member: 261666
Sonork: 109.896
Thanks Meter: 780
Originally Posted by Angello View Post
Hello,
follow this instruction. Your problem will be solved
http://forum.gsmhosting.com/vbb/showthread.php?t=424108
regards
smartsam
Old 08-15-2007, 07:03   #45 (permalink)
Member: 144836
Thanks Meter: 5
i have the same blem when i try to update my clip thank
Searching on COM1
Searching on COM4
Clip found on COM4
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Connected to Server
logging in
Data available
downloading data
please wait....
Data downloaded
Processing Data
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
Flashmode enterd
ClipID=0XXXXXXX
Version :v1.08
can any one post here 5200 latest flash file .. makkah mobile Nokia Base Band 5 ( BB-5 ) 4 05-21-2007 20:28
Page generated in 0.33590 seconds with 11 queries
