07-14-2007, 18:23 | #31 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Guangzhou, China
Member: 38039 Status: Offline Thanks Meter: 6 | Updating still failed, i am keeping trying, the log like this: Searching on COM1 Searching on COM4 Clip found on COM4 Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 Connected to Server Reading sw version in server...:v1.09 logging in Data available downloading data please wait.... Data downloaded Processing Data This may take some time trying to set testmode updating, please wait... Target not responding Trying to reconnect trying to set testmode Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding Trying to reconnect trying to set testmode Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding Trying to reconnect trying to set testmode Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding Trying to reconnect trying to set testmode Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding Trying to reconnect trying to set testmode Flashmode enterd ClipID=0xxxxxxx reading clip SW version Version :v1.08 updating, please wait... CRC error aborting Target not responding Could not update, please use another PC or contact your reseller PS., this is the 2nd PC of mine, the 1st PC can't even find out the CLIP. waiting and keeping trying. BR |
07-16-2007, 15:34 | #34 (permalink) | |
Member: 38039 Status: Offline Thanks Meter: 6 | Quote:
BR | |
07-16-2007, 21:56 | #35 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: Afghanistan; The Netherlands
Member: 261666 Status: Offline Sonork: 109.896 Thanks Meter: 780 | Quote:
I think the problem is inside the USB cable. Solution At the back of the PCB, you can see a resistor, please desolder it/remove it/. Then try again. If your problem still remains, contact me in private. With best regards spitfire | |
07-18-2007, 07:45 | #38 (permalink) | |
It means that the Updateutility could not communicate with your smart-sam. Please make sure you have the latest Prolific Usb drivers installed on your pc. http://www.smart-sam.net/driver/UsbDriver.exe reinstall the drivers. Check if the LED's on your Smart-Sam Turn-on when you insert the cable into the usb port. (it will flash 3 or 4 times) if the LED remains off then you have install the latest drivers. Post the results. wbr Spitfire | |
07-19-2007, 02:14 | #39 (permalink) |
Member: 38039 Status: Offline Thanks Meter: 6 | After removing the 120oh resistor, also failed Hello, mate: I've removed the 120oh resistor of the cable, but the problem still exist. The log follows: Searching for Smart-Sam.. please wait Searching on COM1 Searching on COM4 Clip found on COM4 Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 Connected to Server Reading sw version in server...:v1.09 logging in Data available downloading data please wait.... Data downloaded Processing Data This may take some time Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Could not update, please use another PC or contact your reseller It's not easy to be keeping patient. May my customers can accept the result. Good luck, mate. BR |
07-19-2007, 09:08 | #40 (permalink) | |
check this post. Problems while updating, solved here! with best regards Spitfire Last edited by .:Spitfire:.; 07-19-2007 at 16:02. | |
07-20-2007, 07:36 | #41 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Satcom Bangalore INDIA Age: 53
Member: 17098 Status: Offline Thanks Meter: 51 | Quote: Searching for Smart-Sam.. please wait Searching on COM1 Searching on COM61 Searching on COM5 Clip found on COM5 Flashmode enterd ClipID=xxxxxxxxx reading clip SW version Version :v1.08 Connected to Server Reading sw version in server...:v1.09 logging in Data available downloading data please wait.... Data downloaded Processing Data This may take some time Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Could not update, please use another PC or contact your reseller | |
07-20-2007, 14:01 | #42 (permalink) |
Member: 261666 Status: Offline Sonork: 109.896 Thanks Meter: 780 | It is the GND problem which some may Face. Maybe the GND of the Clip do not make any connection with the metal casing,. Check if screw´s on the Clip is connected to GND of the Clip. You may also try to hold the Clip in your hand while updating. With best regards Smart-Sam |
08-12-2007, 17:21 | #43 (permalink) |
No Life Poster Join Date: Jan 2003 Location: France
Member: 19927 Status: Offline Sonork: joe-lindien Thanks Meter: 58 | Hello, I have one problem for update Clip.I have always "target not found". I have tried with 2 computers Windows XP,and with 2 cables for update but no success.I'm sure my cable number one and PC number one working because my friend have update her clip and no problem. I have solder GND to cover but have same problem "Target not found". Could i send Clip to my reseller for change? PS:Server read serial number and version of clip 1.08 but can't write into clip. |
08-14-2007, 21:02 | #44 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=424108 regards smartsam | |
08-15-2007, 07:03 | #45 (permalink) |
No Life Poster Join Date: May 2005 Age: 48
Member: 144836 Status: Offline Thanks Meter: 5 | i have the same blem when i try to update my clip thank Searching for Smart-Sam.. please wait Searching on COM1 Searching on COM4 Clip found on COM4 Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 Connected to Server Reading sw version in server...:v1.09 logging in Data available downloading data please wait.... Data downloaded Processing Data This may take some time Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Flashmode enterd ClipID=0XXXXXXX reading clip SW version Version :v1.08 updating, please wait... Target not responding, Retring please wait Could not update, please use another PC or contact your reseller |
can any one post here 5200 latest flash file .. | makkah mobile | Nokia Base Band 5 ( BB-5 ) | 4 | 05-21-2007 20:28 |
