08-18-2007, 07:54 | #46 (permalink) |
Junior Member Join Date: May 2007 Location: Netherlands Age: 76
Member: 513276 Status: Offline Thanks Meter: 0 | Upgrade V1.12 Everything went fine with updating from V1.08 till V1.11. But now it stay like in picture, after 20 min I stopped the session. Tried several times. Hope you can solve the update problem cause Smart-Sam clip is very good. |
08-18-2007, 10:29 | #47 (permalink) | |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | Quote:
It seems that there is a problem in processing the data. Do you use any antivirus/firewall? please turn them temporarily off and retry. wbr to_deal_with | |
08-18-2007, 12:49 | #49 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Life's a Journey Age: 44
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345 Thanks Meter: 1,026 | Searching for Smart-Sam.. please wait Searching on COM1 Searching on COM2 Searching on COM3 Clip found on COM3 Flashmode enterd ClipID=13xxxxx reading clip SW version Version :v1.08 could not connect to Server |
08-30-2007, 21:55 | #52 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Afghanistan; The Netherlands
Member: 261666 Status: Offline Sonork: 109.896 Thanks Meter: 780 | Please retry, the clip could not read the Smart-sam's IDentification strings. Please retry, some clips might have the grounding problem. Please search on our support section here if the problem remains. you have to make a connection on the PCB. with best regards smart-sam team |
09-02-2007, 12:05 | #56 (permalink) | |
Please try again. wbr to_deal_with Last edited by to_deal_with; 09-02-2007 at 12:35. | |
10-14-2007, 17:16 | #57 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Guangzhou, China
Member: 38039 Status: Offline Thanks Meter: 6 | Update problem, always "Could not set in Flash mode, please retry", don't know why Hello, mate, When i update my clip, the problem "Could not set in Flash mode, please retry" always occurs, could somebody kindly tell me why? I've not met this problem before. Is there any solutions? Need helps urgently. Thanks in advance. Best Regards The log attached: Searching for Smart-Sam.. please wait Searching on COM1 Searching on COM4 Clip found on COM4 Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.13 Connected to Server Reading sw version in server...:v1.14 logging in Data available downloading data please wait.... Data downloaded Processing Data This may take some time Could not set in Flash mode, please retry |
10-14-2007, 17:31 | #58 (permalink) |
Member: 38039 Status: Offline Thanks Meter: 6 | and then "CRC error aborting" occurred Hello, mate, The followed update problem is "CRC error aborting", I've never encountered this problem b4. Need help, thanks in advance. Best Regards Log attached: CRC error aborting Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.13 updating, please wait... CRC error aborting Target not responding, Retring please wait Flashmode enterd ClipID=xxxxxxxx reading clip SW version Version :v1.13 updating, please wait... CRC error aborting Target not responding, Retring please wait Could not update, please use another PC or contact your reseller |
10-15-2007, 10:07 | #59 (permalink) | |
Member: 261666 Status: Offline Sonork: 109.896 Thanks Meter: 780 | Quote:
Open-up the USB cable, hold with your hand the Green line, then update should be ok. The GND connection in some cases is not suffecient, thats why you could get the following errors like CRC error or Could not connect. wbr smart-sam | |
10-15-2007, 15:18 | #60 (permalink) | |
Member: 38039 Status: Offline Thanks Meter: 6 | Quote:
Best Regards | |
can any one post here 5200 latest flash file .. | makkah mobile | Nokia Base Band 5 ( BB-5 ) | 4 | 05-21-2007 20:28 |
