Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 04-23-2003, 09:42   #1 (permalink)
Member: 7767
Thanks Meter: 3
Dead GD75, but can be flashed.
I've got GD75, which don't power on. I don't know how it dead. I tried to flash it. Flashing is OK, but don't power on anyway and don't enter into test mode.
May be somebody have the same (or like) problem? HW or SW?
Thanks in advance.
Old 04-23-2003, 11:08   #2 (permalink)
BLIDA's Avatar
Member: 15439
Sonork: 100.43816
Thanks Meter: 52
if you flash it and crc is ok i think it's hardware problem.
Old 04-23-2003, 11:33   #3 (permalink)
Member: 7767
Thanks Meter: 3
Yes, CRC is OK. Phone is new.
Old 04-25-2003, 07:27   #4 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 938
May be you have call limit...
Old 04-25-2003, 08:32   #5 (permalink)
Member: 7767
Thanks Meter: 3
I can't check this..... Phone can't enter into testmode Only flashing works.
Old 04-25-2003, 09:13   #6 (permalink)
BufferMess's Avatar
Member: 9856
Thanks Meter: 2
Phone enters flashing mode but does not power on! Looks like hardware problem. I think something related to Power IC. You should desolder it and rebuild balls under it, or replace the whole circuit.
Please post results
Best Regards
Sean Archer
Old 05-04-2003, 18:08   #7 (permalink)
Member: 7767
Thanks Meter: 3
After reballing CPU and Power chip, phone don't power up anyway. Erasing time 2 seconds. May be flash damaged? Somebody have version higher than A07?
Old 05-05-2003, 09:44   #8 (permalink)
BufferMess's Avatar
Member: 9856
Thanks Meter: 2
No, 2 seconds is normal for GD75, they erase very fast. Still, I think one of the circuits is damaged, maybe CPU or power IC. You should check...
Good Luck
Old 05-05-2003, 11:06   #9 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 115
in this case most of the time the flash is damaged (i think the eeprom area is damaged) some times i have succeded in powering on the phone by unlocking it with gold tools .....
Old 05-05-2003, 17:24   #10 (permalink)
Member: 7767
Thanks Meter: 3
OK I'll try to change CPU and Power IC later...... But before, I want try to flash it with higher version. Somebody have it?
Old 05-05-2003, 17:26   #11 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
If you flashed the phone using goldtools then its already hardware problem...
For dead panasonic phones please read old post bout repairing dead panasonic phones...
Old 05-06-2003, 09:08   #12 (permalink)
Member: 7767
Thanks Meter: 3
I don't flash phone with Goldtools. And don't use this program at all.
And what the solution for dead panasonic? Can You tell me?
Old 05-07-2003, 17:32   #13 (permalink)
Danchik's Avatar
Member: 5014
i have another problem ... Phone can be flashed... it enters test mode ... Even i can power on it via cb2000...
But after powering phone off i can't power it on again ...
Any Ideas ?
Old 05-07-2003, 20:17   #14 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 735
@ MODERATOR
just remake the CPU balls n ur phone will work
INSH*****...
Old 05-07-2003, 21:38   #15 (permalink)
Danchik's Avatar
Member: 5014
Thanks i will try
6233 dead can be flashed in jaf but cannot do factory settings maximas007 Nokia Base Band 5 ( BB-5 ) 9 12-11-2007 07:18
6630 can be flashed but still dead .:bono:. Nokia Base Band 5 ( BB-5 ) 7 10-12-2006 18:09
v200 cannt flash but can be read by tst sanflora TST Dongle 1 01-08-2006 15:11
dead 6210,but can be flahed celltrix Nokia Hardware & Hardware Repair 2 04-24-2004 10:42
3310 can be flashed but no power on bre786 Nokia Hardware & Hardware Repair 2 07-01-2002 10:36
Page generated in 0.37338 seconds with 8 queries
