Panasonic Panasonic-News... |
11-24-2003, 17:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: no where Age: 43
Member: 4121 Status: Offline Thanks Meter: 11 | Dead Gd87 help me pls!!! Winmodo flashing gd87 erasing process battery is low and stopped try connect no signalling phone dead help me pls repair solution!!! Thanks |
11-25-2003, 08:32 | #2 (permalink) |
Junior Member Join Date: Sep 2003 Location: Croatia Age: 46
Member: 38266 Status: Offline Thanks Meter: 0 | If the phone was powered off during the flashing.....try to reflash it....but i think that the phone is dead.... this is a good example for all who dont read treads before flashing the phone.................the battery of the phone must be 100% full..before flashing uploading soft reading locks etc. Djadjo |
11-30-2003, 14:58 | #4 (permalink) |
No Life Poster Join Date: Aug 2003 Location: germany Age: 45
Member: 37112 Status: Offline Thanks Meter: 2 | REPAIR SOLUTION for Dead Panasonic GD35-75-92-93-95 87 and ... : solution for phone with BGA or no BGA chip you need : - 1 dead phone and 1 worked phone - hot air station and soldering station - PC with cable with external power - software use WinMoDo with main and language pack - microscope (optional, but recomended) Steps : - desolder from bad phone flash chip - desolder from good phone flash chip - solder in BAD phone works flash chip - connect good phone with cable to PC - run WinMoDo with GANG mode - starting upload - when you see in LCD : Flash loader - disconnect cable from phone - in display you see Flash loader and phone frezee - phone in FLASHING MODE !!!! - YOU NEED DESOLDERING FLASH CHIP FROM WORKED, POWERED AND FREEZED in flash mode PHONE !!!!!!!! CAREFULY !!!!!!!!!!!!! - DESOLDERING GOOD FLASH CHIP from BAD phone (phone still avaible in flash mode) - SOLDER BAD FLASH CHIP in BAD PHONE - PHONE STILL in FLASH MODE - connect phone with cable to computer - press OK - you see uploading process - erasing 7-10 minute and flashing - :-)) smile P.S. use Winmodo with option writing BOOT, MAIN and LP flash WARNING !!!! if you lost original flash chip , you lost eeprom area !!!!!!!!!!!! and when you solder another flash chip, repeat repair procedure and power on phone - phone no powered !!! ENJOY P.S. tested and approved by m.com - GD35, 92, 93, 95,87 ATTENTION!!! AUTOR TAKES NO RESPONCIBILITY FOR DAMAGED PHONES! ATTENTION!!! |
P850 DEAD.PLS HELP ME pls..............bro | skyboy_moon | Samsung Hardware Repair | 0 | 09-20-2007 12:51 |
HELP ME PLS! i need the map for dead Sl45 | edward2002ru | x1x to x45/x50 | 3 | 05-26-2002 13:56 |
HELP ME plS!!! SIEMENS C30 DEAD!!!!!!!!!! | denis kruglov | NON Siemens Brand (ODM Phones) | 1 | 06-09-2001 22:08 |
T-28 World Dead PLS Help me pls....... | Ashwani Gaur | Old Ericsson Phones & Sony Phones | 2 | 05-15-2001 11:19 |
