Dead Pana gd30, need help!!!! Hi i've a dead panasonic gd30. I don't know what to do. The problem is, that it wan't start,i have flashed it with winmodo several times,testmode is also ok(with andromeda),any other program did no set the phone in test mode,i've changed the imei, what to do now?I was told to flash it with uspu but i cant find any cracked version that would work. please help |
search vikknet gd50-30/repair/unlock fix this on 2sec |
I forgot to write,i have tried Viknet versions 1.0 & 1.1 and it didn't help,the phone want boot,is it possible,that something with the h/w is wrong? |
try again play with battery you must fight him until you win :) |
Thx i'll try tommorow because the battery is empty now, i'll post the results regards |
i think problem about some calibration data missing.. if the imei is okay ! and if you can flash your phone that mean it is not in ( Warning Authorized ) i think you should try Neo tool for this.. You can download here Good Luck .. Best Regards Oz.. |
