Flashing GD68, but can't power on, GD67_fixed solution can't help Flashing GD68, but can't power on, GD67_fixed solution can't help. Any ideas??? |
Try to flash it with WinDoModo boot - main - language Regards |
:) I did try it long time ago. but thanks |
try to flash it with A33 version... also check if u can charge the phone or not ??? and try to read the phone with CB2000, if u get IMEI Error then the eeprom of the phone is bad.... WBR Syed |
I thank you seek the pack languague a33 in French |
your solutions not work |
does anybody have solution for repair eprom ? two phones say read imei fail. after changing their flahs chip (place to place).they are flashing but not power on.before change chip they was working(29 rus ver both) :confused: |
It does not work after changing flash chip...if u plan to swap flash IC then u got to swap the same CPU as well !! WBR Syed |
ok i have change cpu on both phone place to place so phones starts .but in one phones fault going with cpu.i need to change cpu .what can i do ,phone will no start with new cpu!!!! |
