Panasonic Panasonic-News... |
01-03-2001, 18:49 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | g520 charging without turn-on after unlock .. this phone is crazy .. after unlock it using service software (dos program ) ... tried before too many time .. phone worked 100% for a minutes and then dead . when charging the charge indicator is on display but when press-on its hide and leave ON button its come back .. untill i remove charger .. whats that HW or SW PROBLEM ?? THNX |
01-04-2001, 06:23 | #3 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | Hi, Try another G520 and run the G600 Check-Box and push F7 for read Charge Parameter(RSSI).After reading parameters Press F9 and turn the phone off.Connect dead phone and look at the difference between of them.IF there is any difference Push F6 and enter values.I will send you 2 flash files for old and new one.But i must config it. First try the method which i mentioned above. Best Regards. |
01-04-2001, 12:45 | #4 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | thnx about replay friends , i tried write imei again .. and its ok wrote and its allready was in phone .. and phone still dead . - havnt another g520 .. and cant get . need more help plzzzzzzzzz big problem .. thnx |
01-06-2001, 00:02 | #5 (permalink) |
Freak Poster Join Date: Nov 2000 Location: ------
Member: 2485 Status: Offline Thanks Meter: 1 | hello friend I affirm that most problems with dead Panasonic were from IMEI . Meshoz , when you write Imei did the phon beep . If yes so the cammand is accepted , turn the soft off and then on then read phone and look is there changes in IMEI : only one F in the imei can cause problem . If the phone doesn't beep when you write Imei so the version of soft Is high and you need to flash the phone... I will call you to morrow and try to gether to resolve the problem . |
Lg km710 not turn on after unlock | tolip | VygisToolbox | 0 | 03-27-2009 00:34 |
v3re wont turn on after unlock | krackpack | Smart-Clip | 2 | 07-01-2008 03:33 |
E1070 not turning on after unlock with smartmoto | zenadia | Motorola P2k | 2 | 03-23-2007 15:44 |
V3t does not turn on after unlock with USB smart as V3i | enrocas | Motorola P2k | 0 | 12-26-2006 01:40 |
k750 does not turn on after unlock | Blitzkrieg_Hop | Cruiser Suite | 9 | 05-22-2006 15:18 |
