Panasonic Panasonic-News... |
12-14-2000, 10:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | GD-30 .. DEAD . no green light GO ON .. i hate really this Gd-30 phones .. i got another destroyed 1 .. i destroyed it too it DEAD NOW .. plz help me .. its A13 soi decided to use safe wa to unlock it and i think its downgrade it to 09 ok . i tried to flash it by USPU4.3 its dectect phone version 100% aftewr pressing NO but when pressing flash button green led don't power-on .. NOTHING HAPPEN ... !! i got this problem too with GD90 but DOS FLASHER WORKED 100% .. its somthing like igination in siemens or what !! .. also winmomdo don't See mobile when off . by luck onetime after too many tries .. USPU detetcted it and green loght goes on then i waitied some minutes with counting anything .. then phone displayed .. " FULLY CRC ERROR " and phone DEAD .. program hang .. re-tried too too many times reflash it . nothing happened .. winmodo still .. viknet and other dont goto testmode .. HEY !!! an help plzzzz urgent . regards |
12-15-2000, 07:33 | #2 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | hi Meshoz i got your mail, i have unlocked maybe 20 GD30 so far, but i have never flshed them, i am realy sorry that i can't help you, i write how i do it, may be it helps you in some way: i use VirtualX unlocker and then Zoran, or better is VirtualX and then Neo's v.7.3 only once i had problem with one Phone i could not make calls, i used then Viknet 1.0 and repaird it so long till it was dead and then used Neo's to restore it and everything was fine. if you need any of these Program i will send it to you. but try Neo's to restore the Phone maybe it helps WBR Meam |
12-16-2000, 10:03 | #3 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Thanks My Friend for your replay .. and thank u all .. really my problem is still here with solution .. but the new is : the file in USPU34 is 0 BYTE . !!! so i shocked .. i flashed phone with 0 byte file .. " i swear i got uspu34 like u all from gsmgods site but !!!! " anyway , my problem now is " why green led don't power-on after connect cable !!!! ??? " really i tried too many times and tried in another pc .. is there any dos flasher for gd-30 ?!??!?! i had same problem with gd-90 but dos flasdher worked 100% .. help bye |
12-18-2000, 23:13 | #4 (permalink) |
Major Poster Join Date: Oct 2000 Location: Slovenia
Member: 2326 Status: Offline Thanks Meter: 0 | Hello!!! I have similar problems with friend's gd30. Phone was totaly dead. I tried with viknet phone was in test mode but don't work. Zhan I try with gd30Fmy(it's an old dos program) type EMEI and prduct version and Viola Phone was working and upgraded to gd50. Mail me if U don't have this proggy. Alternative No1:Repair your gd 30 First run gd30 repair (G30fmy.exe) connect to COM1 and push ON type IMEI and run the gd30 repair on the end power OFF the phone. Run zoran repair(GD30-50 unlocker v 1.02) and that it is your phone is repaird. Alternative No2: First you must have zoran unlocker for gd30-50 v1.02 and virtual unlocker 2000 for panasonic. Connect to COM1 Tray to unlock with virtual 2000 your gd 30 about 25 times everithimes when you unlock you can hear the voice of bip when your gd 30 gives no more voice of bip then run zoran repair ver 1.02 and push on and thats it your phone is unlocked. Work on all version gd 30 to below 21. I wish U luck. Regards ------------------ Best Regards Greetings from Slovenia [email protected] |
Myc4-2when power on the green light is on only | beneto | Sagem Hardware Repair Area | 2 | 02-12-2010 15:50 |
Box not found, green light its on | rushwhq | TSMbox+ | 6 | 04-06-2008 15:51 |
C650 charging problem only keyboard lights going on | dominik | Motorola P2k | 14 | 10-03-2007 15:40 |
gd 30-dead-wrong imei-needing flasher | cosmo | Panasonic | 0 | 05-30-2001 14:32 |
No green light is turn on??? | wpl | Panasonic | 0 | 12-08-2000 00:01 |
