Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 05-08-2004, 20:42   #1 (permalink)
Member: 64835
gd 87 flash help
hi guys just tried flashing my gd87 to a22 but when i start it, it says failed to open com port then in the progress report window it says changing protocol. but on th front little screen of the phone it says flash loader gd87 version 1.4 parameters please can someone help me i'm lost?????????
Old 05-08-2004, 23:18   #2 (permalink)
Member: 64835
forget this i've succesfully managed to flash it down to a22 and unlock the phone and upgraded back up to a55 but i can't recieve incoming or make outgoing calls. why, i did everything right does anyone know how to solve this???
Old 05-09-2004, 00:27   #3 (permalink)
LEE5K's Avatar
Member: 28588
Thanks Meter: 2
sounds like your phone is blacklisted
Old 05-09-2004, 00:55   #4 (permalink)
Member: 64835
what do you mean blacklisted how come it lets me send msgs though?
Old 05-24-2004, 10:34   #5 (permalink)
Member: 65020
are you using winmodo if so i had the same problem the other day have you tried to change the baud rate to 115200 this seemed to work for me .if you are doing this to unlock the phone if you need other software to i.e cb2000 to clear memory because when you send a mms it will switch the phone off, also you need crack2d to read the unlocking code off the phone if you havent got the software let me know and ill send it to you free of course.
my email is:
[email protected]
p.s. what firmware is in the phone
Old 05-25-2004, 16:57   #6 (permalink)
Member: 64835
gd87 flash
thnx gazman i got it all sorted now my phone was blacklisted and needed new imei no. but thnx anyways
Old 05-25-2004, 18:10   #7 (permalink)
Member: 62617
help
xxxxxxxxxxxxxxxxxxxxxx
[glow=red]use only english pls[/glow]
Best regards
Irinel
Old 05-25-2004, 19:06   #8 (permalink)
50-pounds's Avatar
Member: 48042
there is a guide i worte on how to does all this plus more have a look for think the title is named "read for downgrading the panasonic" or somthing like it!
Injoy
50!
Old 05-27-2004, 10:52   #9 (permalink)
Member: 65020
glad to help your welcome
need gd 87 flash softwear vinay_sharma Panasonic 0 08-20-2006 09:25
gd 87 flash branev Panasonic 6 05-18-2005 13:40
GD 87 Datacable Help bananaman Panasonic 4 04-13-2004 07:39
gd 87 flash problem desbloqueo Panasonic 1 09-23-2003 13:37
Gd 87 Flash File Mobilebiz_ORB Panasonic 1 09-21-2003 15:15
Page generated in 0.20732 seconds with 9 queries
