Panasonic Panasonic-News... |
02-06-2004, 12:41 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Location: Cymru Age: 63
Member: 52517 Status: Offline Thanks Meter: 0 | GD 87 and Winmodo |
02-06-2004, 13:24 | #3 (permalink) |
Member: 52517 Status: Offline Thanks Meter: 0 | Cheers, I should of been more accurate with the info...the P.C. dosen't lock up, I can stop winmodo without the 3 finger salute,the P.C. is working o.k.... it's just after signalling in winmodo and the signalling reply from the phone ..that's it..nada...no erase message..nothing..just signalling from winmodo and "Flash Loader GD87 Version 1.4 Signalling" from the phone no matter how long I leave it? The GD87 is on Orange if that's a help? Plus edit tools 2 doesn't work with the cables...Com port problem maybe? |
02-06-2004, 13:52 | #5 (permalink) |
Member: 52517 Status: Offline Thanks Meter: 0 | Cheers again Loren, I'm in my Xp box at the moment...which I don't fully trust...so when I finish trawling the net I'll switch to Me and do as you say...I should of known better I usually only do Nokia...which has always worked...so far...this is the problem with doing favours for people, but Hey! it's a learning curve if nothing else gut feeling tho' is ....shoulda stuck to what I knew |
02-06-2004, 14:33 | #8 (permalink) |
Member: 52517 Status: Offline Thanks Meter: 0 | This maybe the problem......I may have to make a Win 98 partition....but it involves shrinking one of the others, Shame this stuff doesn't work in Mandrake.....yep Blartiartfast you do power on after winmodo tells you it's signalling,....and the phone tells you it's signalling back...it's after that nothing happens the phone and winmodo just sit there signalling...sorta mutual semaphore, but no resultant actions I shall create a 98 slice and report back....maybe this an Xp thing? I generally run all my Nokia clip progs under Me..unless they are irda..which tends to work under Xp better....I just love a mystery!!!! |
02-06-2004, 16:14 | #10 (permalink) |
Member: 52517 Status: Offline Thanks Meter: 0 | mmmm....O.K....sequence of events.....clip GD 87.....start Winmodo3.3b...click download....winmodo say's ...signaling.....GD 87 in small display says signalling.....That's it???? nothing else from GD87 or PC...no rewrite....just signalling.....I will try the 98 box.. in a turnover...and report back. |
02-09-2004, 03:40 | #14 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: England
Member: 48042 Status: Offline Thanks Meter: 1 | Quote:
50! | |
02-10-2004, 18:31 | #15 (permalink) |
Member: 52517 Status: Offline Thanks Meter: 0 | arrghh Well it turns out both cables I had were something...but not unlock???? Both work with CB2000 but bog all else? So in desperation.....I got another cable from http://www.mobilefun.co.uk and guess what?? it works, downgraded to A22 no probs, so I've 3 cables now...all three are 9 pin com 1...but are all wired different internally? So it's unlocked, but whilst reading other posts found that the imei number is printed under the battery, on checking the phone *#06# it doesn't match? On asking the guy where he got it ...he now tells me it's off a mate[not what he said originally] who said it was working when he sold it! Assuming it's not nicked is it feasible to change the imei back to the printed one? |
Using Winmodo Gd 87 Died | PhoneDoctor | Panasonic | 10 | 06-04-2004 09:47 |
gd 87 power's on and off | t100 | Panasonic | 27 | 03-02-2004 00:00 |
gd 87 dead after winmodo | surfer2go | Panasonic | 1 | 11-03-2003 15:15 |
Urgently need russian lang. pack for gd 93 for winmodo | dimon | Panasonic | 0 | 02-09-2003 16:34 |
winmodo for gd 75 and flash complet | SANTOGSM | Panasonic | 0 | 09-30-2002 15:49 |
