Panasonic Panasonic-News... |
01-19-2001, 20:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2000 Location: germany Age: 49
Member: 2321 Status: Offline Thanks Meter: 1 | need PRog for GD90 |
01-22-2001, 00:26 | #5 (permalink) |
Member: 2321 Status: Offline Thanks Meter: 1 | hi ...ja habe ich ...ich habe ein datenkabel aber die software die runtergeladen habe funkioniert nicht das GD90 wird nicht erkannt zumindest bei IMEI scheitert es..kann sein das ich ein falsches kabel habe?????? bis dann MFG |
01-31-2001, 13:46 | #6 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: CHANDIGARH - INDIA Age: 59
Member: 2822 Status: Offline Thanks Meter: 152 | KINDLY LET US KNOW WHAT YOU ARE LOKKING FOR,I THINK ALL MEMBERS CAN EASILY UNDERSTAND ENGLISH. REGARDS ASHWANI GAUR [email protected] Quote:
01-31-2001, 17:55 | #7 (permalink) | |
No Life Poster Join Date: May 2000 Location: Malaysia and Singapore Age: 49
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Yes use English plsssssssss.......... Vid Quote:
02-04-2001, 20:39 | #8 (permalink) |
Member: 2321 Status: Offline Thanks Meter: 1 | hi i have an Panasonic GD90 i can turn on the pohne network is ok but there is an little key upper right ...i dont no what is it somebody sey it it is from Panasonic they have LOCKED the Phone it is true and what can i do??????????????# CU thx sorry my bad english |
02-05-2001, 18:10 | #9 (permalink) | |
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi LOAD_SHAH, flash you phone. Vid Quote:
02-06-2001, 13:07 | #11 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | Hi lord Shah, you can flash Gd90 with Perom20 but you will probably have charging problems afterwards that you have to repair with other programes and i am not so sure if flashing would solve your problem with the locked keys. WBR Meam |
02-08-2001, 10:37 | #13 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | Hi Lord, i sent you the flasher, hope you got it. to see the Software version, ihave just tried it with Panasonic service 3.1 by Andromeda, with this program you can see the Version and the Security Code, may be that is all you need, try Andromeda before you do any flashing, i tried it with GD30 because i don't have GD90 at the moment, but it must work, once you know what the Security Code is you just type the 4 digits and the phone works, if you don't have the Prog, i will send it to you WBR Meam |
Need IMEI Rapair prog for samsung u600, for free | Gadde | Trident/AGERE Platform | 2 | 09-18-2008 13:43 |
I need good flashfile for GD90 B15 and B16 | vilkin | Panasonic | 2 | 12-14-2005 17:12 |
How to work with autocal progs for Samsung - help need!!! | Sonia | VLSI, Conexant, Skyworks and Old Models | 1 | 11-10-2002 03:00 |
I need serbian for GD90 | bojans | Panasonic | 1 | 07-24-2001 22:05 |
Need flash for GD90 15or16 | Pandemonio100 | Panasonic | 0 | 04-21-2001 11:52 |
