Panasonic Panasonic-News... |
06-22-2003, 17:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | GD67fix easy way -Rename gd67sp.spu to PA13.bin -Run ghost3D and select GD30 (I select gd30 stiil not enter test mode but select model GD90 OKAY) -press partial flash and select PA13,press and hold power buton -when is finished you will see on LCD test mode and disconect your phone,phone must be in test mode or any words (version.. erasing but I dont see test mode) wait finish. Not remove batery only remove cable. GD67fix You open GD67 fix and select rel file and plug cable You phone working but simlocked so you use gd6x-gd8x_spunlock |
06-23-2003, 18:53 | #3 (permalink) |
Freak Poster Join Date: Apr 2002 Location: eastern europe Age: 46
Member: 11375 Status: Offline Thanks Meter: 0 | question HI I seen your sollution and i would like to ask you some question before making myself mad. I just killed a gd67 by flashing it and the battery was uncharged so she died after erasing the whole flash. My question is if your sollution do you think it will help me ?! Thanx a lot. |
06-23-2003, 19:07 | #4 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | ? Tell me man you problem what? İf do you have GD67 dead phone only try 1000000000 % and tell me what problem Only PA13.bin send phone with PANGD (select GD90) after remove cable but you must see any words LCD you open wModo and sen A39 rel Good LUCK |
06-26-2003, 07:33 | #6 (permalink) |
Freak Poster Join Date: Aug 2002 Location: www.unlockbyserver.com Age: 49
Member: 14442 Status: Offline Thanks Meter: 4 | @bestcool i did step by step ,as u said above,but my phone didn't gave any response...pls tell me brieflly.... i used panaGd USSW v6.5 by ghost3d.. connect cable to phone..select partial file ,as u said above,select both gd30/50 and gd90,but software said... Trying to connect phone.. (after some time while remain pressing the power button..) Enter Flash Mode:Error... pls tell me the solution... (my phone shows red light while connecting the charger) Thanks Raman [email protected] icq#167901740 |
06-26-2003, 08:49 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | No way my friend. You have erased boot sector. It can not be rewritten if you took out battery or it was down during flash erasing. The only thing you can do is to use external flash programmer. Non of the mentioned here methods will help you. The technology Panasonic uses does not support the methods discussed herein. Best Regards Sean Archer |
06-26-2003, 13:33 | #8 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Armenia Age: 46
Member: 15440 Status: Offline Thanks Meter: 15 | THANX TO bestcool!!!!!!!! My dead GD67 alive when I tried this solution!! It works for me, then I unlock it and install the russian language!! Good work!! THX!!! |
06-26-2003, 19:45 | #12 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | 1 reminder: POSSİBLE : This SOLUTİON NOT WORK FOR ALL DEAD GD67 PHONES (Some not working because you phone possible completely dead) |
easy way to repair config key 0000 SL1/SL2/SL3 without rpl hello mats the easy way t | sureshplaza | Nokia Base Band 5 ( BB-5 ) | 12 | 05-23-2010 22:46 |
easy way to repair config key 0000 SL1/SL2/SL3 without rpl hello mats the easy way t | h_mobiles | Nokia Base Band 5 ( BB-5 ) | 6 | 01-13-2010 20:53 |
Easy Way..... Fast Way ..........Enjoy | SoftSkiner | Sony Ericsson | 15 | 09-09-2003 09:09 |
Another easy way to repair X35 dead mobiles 100% working | Pk2GSM | x1x to x45/x50 | 12 | 08-18-2002 15:59 |
UNLOCK THE EASY WAY ! ! ! ! | chrislowthian | Main Sales Section | 1 | 08-29-2001 23:49 |
