Panasonic Panasonic-News... |
07-14-2003, 14:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: hk
Member: 33368 Status: Offline Thanks Meter: 8 | GD87 Dead after bad flash and battery removal For info, flash started with Winmodo and stopped very shortly, then I removed the battery (I know I should have read several topics before). I tryed Winmodo again : no connection And phone does not start at all. Also, I don't know if usefull, when I plug the charger, the red light is on. Having him is what the free gd87 make alliesing die? |
07-23-2003, 09:22 | #4 (permalink) |
Junior Member Join Date: Jul 2003 Age: 49
Member: 35195 Status: Offline Thanks Meter: 0 | I have the same behaviour but the only thing that i have done is when i have clicked on download i have not set boot to green. I have not take the batery off the phone during flashing. The flash progression windows was just saying signaling What can i do ? Thanks for your help |
07-23-2003, 10:06 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Earth Age: 54
Member: 17189 Status: Offline Thanks Meter: 66 | hi there try first with fully charged battery to flash it again now when it says signaling then at this moment press the power button ( the one that gets the mobile to start ) but choose always the main and the boot ....ok if the mobile get died then there is some logger for panasonic... this would read the phone and send a log file to a server the U can flash the phone back and make it alive.. have fun regards from a traveller |
07-23-2003, 11:04 | #6 (permalink) |
Member: 35195 Status: Offline Thanks Meter: 0 | I will try again tonite but i did not understand the second scenario if it is dead. I mean at this time my phone does not switch on but when i charged the batery the light is red. Some people says that in this case the phone is half dead and i can reflash it. Is it true ? When you say there is some logger software ... Can you give me a name please. What the logger does excatly. It is able to dump the flash ? What do you do after getting the log file to reflash it ? Thanks for your help Lolotuit |
07-23-2003, 11:15 | #7 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: VI Age: 53
Member: 17084 Status: Offline Thanks Meter: 14 | Quote:
U can reflash choose main + boot | |
07-23-2003, 14:47 | #8 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya No logger or server will make Your dead panasonic alive !!!! If You did not write boot or some error appeared during flash process Your phone is very dead... Only way to revive is to program flash chip itself externally ( don't have to flash whole chip, just boot ) or use hot swap of chips from working and broken phone... In both cases You need very good equipment, a lots of nerves and much luck... And as mr_x4you said don't play with panasonic if You don't know exactly what r u doing... Br Vule |
07-23-2003, 17:16 | #9 (permalink) |
Freak Poster Join Date: Jun 2003 Location: London (streatham hill)
Member: 31471 Status: Offline Thanks Meter: 7 | totally with y....I told many people about the dangerous of flashing,.. I did flash more than 20-30 phones before reader 6.0 ...as no solution at that time with A39 Organge GD87 ..... to be honest, I did kill one totally!!! and but repaired... now, I paid log for reader 6.0 to supplier ...instead of using a FREE solution to unlock... why I have to pay if I am exprienced in flashing???? cos I say thousands time..it's very dangerous for flashing in panasonic!! |
07-23-2003, 17:18 | #10 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | and that hot swapping is very very difficult in GD87 the flash is BGA type...and you need to be a master in BGA soldering/desoldering.... WBR SYed |
07-23-2003, 17:43 | #11 (permalink) |
Member: 17189 Status: Offline Thanks Meter: 66 | the PanaReader this reader 6.0 can solve the prob as I heard right??? that I red at some forum don't remember (please is that true??) ( people must try and error that is the best way of learning even if might cost them sometime alot) thanx in advance |
07-23-2003, 20:39 | #13 (permalink) |
No Life Poster Join Date: Nov 2002 Location: D U B A I Age: 45
Member: 17651 Status: Offline Sonork: 100.81230 Thanks Meter: 318 | @ syed could u plz tell us how to Replace PCB in Gd87 ..if u know that ? its totaly Dead after removing battry in half flashing .. Thanks n Regards |
07-23-2003, 21:28 | #14 (permalink) |
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | PCB is more than half a phone...Rest is battery, display and housing... Changing PCB is easy...Open phone, remove PCB ( printed circuit board ) and put in new one... BR Vule |
07-24-2003, 05:53 | #15 (permalink) | |
GD87 Dead after bad flash and battery removal | rs7k | Panasonic | 9 | 07-02-2003 13:43 |
help me !!! siemens a50 dead after bad flash | dragoss | Phone Unlocking Codes & Maps | 4 | 06-29-2003 20:59 |
dead after bad flash.....S40 v3.2 cs-lang | bart3 | x1x to x45/x50 | 1 | 12-28-2002 11:21 |
a2618 dead after bad flashing, need help | bedjo | Old Ericsson Phones & Sony Phones | 6 | 04-15-2002 22:31 |
T205 dead after bad flashing .... | 205T | Motorola ODM | 1 | 03-19-2002 04:20 |
