Panasonic Panasonic-News... |
07-06-2003, 08:10 | #5 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | this is software problemin GD87....upgrade your GD87 to a newer version...this problem will be solved.... if still same check simtray and reflow the CPU or remove, reball and resolder the CPU... problem will be solved.. WBR Syed |
07-09-2003, 21:15 | #7 (permalink) |
Freak Poster Join Date: Aug 2000 Location: slovenia
Member: 1971 Status: Offline Thanks Meter: 0 | I repaired 1 pcs using next method: Maybe some of the steps are 2 much but I did it these way: It occured doing these after downgrading from a38 to a21 and using Ghost 3d by changing imei. repair: 1. upgraded back to a39 2. memory clear in CB2000 3. downgrade to a21 change imei again to some other number 3. read codes again and it worked. BR uniden slovenia |
GD87 Sim Error! | Nodski | Panasonic | 13 | 04-23-2005 15:21 |
GD87 sim error pls help??? | proxy_gsm | Panasonic | 2 | 04-22-2004 00:09 |
could sum1 plz help me out? Sim error on GD87 | karen5000 | Panasonic | 16 | 01-11-2004 23:46 |
gd87 sim error | tanmay | Panasonic | 3 | 12-15-2003 12:56 |
gd87 sim error | zoki | Panasonic | 4 | 05-27-2003 22:45 |
