Panasonic Panasonic-News... |
09-21-2001, 11:18 | #1 (permalink) |
Major Poster Join Date: Apr 2000 Location: Hungary
Member: 1226 Status: Offline Thanks Meter: 1 | GD30 Unsuccesfull Unlock... I unlocked my GD30 A14 phone with viknet V1.0 unlokcer/repairer. The phone unlocked, but on the goes to the Unatrhorized state. I did the continous repair/unlock process while the FFFFF0 apperaed. But the IMEI is still FFFFFF0 and the phone is still in the Unathorized state. I tried to flash with the USPU4.3,m the software reads the firmware version, but the flashing process is not started, the same symthom with Winmodo2.8. I am using the rx-tx gnd, V+ ignition cable. Someone Can help me? How Can I repair the dead phone? Regards, GreaT |
09-22-2001, 23:37 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | Hi GreaT<br />I had the some problem sometime back with A13...till date couldnt solve it.If u find any solution please let me know. Hams |
09-26-2001, 08:52 | #4 (permalink) |
Freak Poster Join Date: May 2000
Member: 1364 Status: Offline Thanks Meter: 0 | Hi, GreaT..<br />I have 2 version's of VIKNET 1.0 software - with 2 and 3 button.. For good result you must use 3-button version and next instruction: 1.RUN program "GD50 repair&unlock by viknet v1.0 " <br />2.press "set test mode" and ON phone..phone goes test mode..<br />you will see IMEI and SERIAL..you can enter any ...for example<br />(' first make backup original IMEI and SERIAL') IMEI : 555555555555555<br />SERIAL:IIIIIIIIIIIIII 3. press "Repair and Unlock"<br />you will see again warning message.. repeat this steps Until you see<br />IMEI: FFFFFFFFFFFFFF0<br />SERIAL:yyyyyyyyyyyy that is very important..at this point you will enter<br />IMEI : 449121882548521<br />SERIAL : 125005687236501 ( not magic numbers just fit) and press "Repair and Unlock"phoen lights will up..and nothing on the screen.. (!!! this important)<br />press keys..and lights still ON..keep about 2-3 minutes of this position..<br />(keep pressing keypad,linghts ON and nothing on the screen..)<br />4. after 2-3 (1-2 monutes) minutes OFF the phone and ON again..THAT'S ALL.. After reflash it to GD30 09 version with winmodo.. |
gd30 after unlock dead | rpbongp | Panasonic | 9 | 08-03-2005 18:38 |
GD30/50 unlocker 1.02 | Meam | Panasonic | 1 | 11-18-2000 08:15 |
GD30 w14 unlock help | GreEn | Panasonic | 6 | 10-09-2000 16:35 |
Does work GD30 50 unlocker 1.1 by Angelo with GD30 a13? | tomi_no | Panasonic | 0 | 08-17-2000 13:20 |
GD30 a13 unlock | tomi_no | Panasonic | 1 | 08-15-2000 03:03 |
