Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 07-07-2003, 16:25   #1 (permalink)
Member: 33430
what kind of cable can use for upgrade?
what kind of cable can use for upgradeĦ˘CB2000 and crack2d?
Is the original Serial Port cable do this?
thanks!
Old 07-07-2003, 23:48   #2 (permalink)
Member: 29308
Yes, any serial cable or USB cable can do it, but if you wanna use yoou crack2d, you have to setup your cable on com port 1, because the crack only work on com port 1.
Old 07-08-2003, 03:47   #3 (permalink)
Member: 33430
thank you!
use for crack2d must cover the pin4&10?
Old 07-08-2003, 03:52   #4 (permalink)
Member: 29308
yes, it's a MUST, without doing that it not work.
Old 07-10-2003, 19:21   #5 (permalink)
kingmobilephone's Avatar
Member: 31471
Thanks Meter: 7
yes....phone can only be put in test mode if pin4&10 disabled..
but until now, I haven't got any datacable (com) ...as all I got is service cable with pin4 & 10 disabled for unlocking and firmware upgrade....ToT!
by the way, I don't suggest people using USB to do the upgrade..
as u can't use CB2000 with USB cable (as for CB2000) ..as u can't disable pin 4 & 10 in USB cable (correct me if I am wrong)
Old 07-11-2003, 00:35   #6 (permalink)
Member: 29308
I'm using USB cable for flashing and for CB2000, it work fine for my phone, i've using it all the way from start till now(upgrading, flashing, function clearing, ex....), so I don't know why you say can't use USB cable for CB2000.
what kind of precautions we use for save ( p-key ) while using zulea software salman_4_ever Nokia Base Band 5 ( BB-5 ) 1 04-27-2009 15:52
what kind of cable to unlock (cu400-cu500) LEE-MOBILE VygisToolbox 7 05-24-2008 02:13
what kind of cable need 411i ? akbarbaba NEC 2 09-19-2006 14:48
what kind of flash files use ns-dongle? CLIFFORD25502 NSPRO 2 12-05-2005 17:17
Page generated in 0.16041 seconds with 9 queries
