Panasonic Panasonic-News... |
12-10-2004, 18:41 | #1 (permalink) |
Banned Join Date: Aug 2004 Location: Gsm Unlockers Awareness Report
Member: 76978 Status: Offline Thanks Meter: 15 | Get A100 Flash File I have installed "Panansonic Muti-Mbf Tool" I just need some advise, The program shows the following Main Core, Mapping, Lang. Pack. Questions: Do I need to put Check mark on all three Main Core, Mapping, Lang. Pack? Also I have three files are these setting correct? 040609_BN1PAC_c018_lpcL03_dfM06_updateLibmf.mbf (3.48MB) = MAIN CORE A100_0.18_asuu_01a.mbf (177KB) = Mapping 040609-BN1.PAC-LP4.L03.07mf.mbf (633KB) = Lang.Pack Do I need to check mark both (Keep Media FFS) and (Keep FFS) ? What is the reset on the problem used for? Last question do I need to Flash all three files to unlock the A100, I would like to keep the my Lang.pack because I do not know if XXXXX-LP4.L03.07mf.mbf has Portuguese. If anyone in the forum can help out with these questions, I will really be thank full. After you flash A100 to unlock try these.. **00012*00000000# 6 to 10 until phone says Blocked test if phone unlocked if not then try. **00032*00000000# 6 to 10 until phone says Blocked test if phone unlocked if not then try. *01763*737381# Please post results good luck all. You can find the A100 flash file in http://people.itu.int/~emartine/ only until Dec 24 cause i need the disk space... |
12-11-2004, 01:51 | #3 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
The file settings are correct, if you make mistake it ll not be accepted by the downloader.. if you keep check mark on the FFS and MEDIA are .. you are excluding those area from being flashed, for the purpose of flashing to unlock its good to leave the FFS area unchecked,... I stand to be corrected. bR | |
12-11-2004, 02:03 | #4 (permalink) | |
Member: 76978 Status: Offline Thanks Meter: 15 | Quote:
BR | |
12-13-2004, 17:17 | #6 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Vancouver, Canada Age: 56
Member: 26867 Status: Offline Thanks Meter: 3 | Quote:
12-14-2004, 00:57 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | hmmm i think unlocking cant work with this flashfile ... it looks like v18 ... and that version doesnt allow unlocking .... am i right or it is mappimg'dependable thing b.r. ALexandar. |
A100 flash file | ciavatta | UfoTools | 3 | 09-13-2005 09:20 |
Pana A100 flash file ITA | ciavatta | Panasonic | 0 | 09-13-2005 08:32 |
Panasonic A100 Flash File inquiry | Chryse | Panasonic | 1 | 07-10-2005 07:32 |
Need A100 flash file | kisa55 | VLSI, Conexant, Skyworks and Old Models | 0 | 12-27-2002 21:12 |
Need A100 flash file | dhgsm | VLSI, Conexant, Skyworks and Old Models | 2 | 01-08-2002 14:50 |
