Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Panasonic
Panasonic Panasonic-News...
Old 07-09-2003, 13:19   #1 (permalink)
Member: 33368
Gold tools the ghost3d can not install.Does someone can install?
Such as can?Thank?( gd75 solution eeprom)
speedcotop@163.net
Old 07-09-2003, 13:50   #2 (permalink)
Moderator
Syed's Avatar
Member: 19979
i can ...get me on ICQ ill explain
Syed
Old 07-09-2003, 14:12   #3 (permalink)
Member: 33368
Can you write last this?I have no an icq. thank you...
Old 07-09-2003, 14:28   #4 (permalink)
Moderator
Syed's Avatar
Member: 19979
you need the key generator.......if u dont have ICQ then yahoo or MSN that will be easier..
Syed
Old 07-09-2003, 19:09   #5 (permalink)
Member: 13808
best to read the instuction in teh software or read old posts
Warning''''.. ;;;you have to be careful when using the software
Old 07-30-2003, 23:42   #6 (permalink)
Member: 6530
can someone explain how to install software
Old 07-31-2003, 04:13   #7 (permalink)
Sun
Sun's Avatar
Member: 17084
Hi all !
I don't remember, correct me if i'm wrong.
Install Gold Tool u must have key generator sw (dowload in some site ).
1.Run install software its give you tips for install follow him.
2.Look your main key then generator key take your code then continue install.
3.Restart computer it's require key again, generator key and continue.
Notice:Never do not any Debugger,Spy Tools or any etc Sw.Cause may you get damaged. Also For save install you need close all applc. like ICQ,MSN,Norton etc.!
Best Regards
Old 08-03-2003, 03:08   #8 (permalink)
Member: 24435
disable antivirus and than install...
Old 08-03-2003, 11:18   #9 (permalink)
GSM Deals's Avatar
Member: 3936
[QUOTE]Originally posted by sun
[B]Hi all !
4.Restart computer and copy "AppInit1.dta" to directory where GT2.0 is installed run soft it will require key again, use key generator the progy will be registered twice then close the registration window and other runing applications restart gold tool again and here you are
regards
Cao! mobileEx 3.3 (rev1.7_fixed) NK5030 can not FLASH! HWK you can use! lxh-studio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-27-2010 10:59
n82 can not read all pm,can reading part of! Merry MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-15-2010 12:03
HWK can not boot C180 !!!! but can read info only tsarkh HWK 2 10-23-2008 18:51
Help..my Cruiser can not attach to phone after install new 13.11 blaknightz Cruiser Suite 2 10-23-2008 18:16
Panasonic Gold Tools by Ghost3D boboke Wanted Products 0 07-03-2002 04:50
Page generated in 3.09030 seconds with 11 queries
