Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 07-15-2004, 10:37   #61 (permalink)
Member: 56335
Thanks Meter: 25
Hello, the cable for GX60 is not the same that T191, rx and tx are inverted !!
Old 07-15-2004, 11:46   #62 (permalink)
electrohicham's Avatar
Member: 12504
Thanks Meter: 10
sorry sir you are wrong i unlocked manny x60 with normal T191 cable and work 100%
Old 07-16-2004, 03:02   #63 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 776
Originally Posted by nokevin
If you all want your X60's & X70's unlocked email me
[email protected]
Steve
i would not trust any hotmail address, unless u have money to throw away.
Old 07-16-2004, 09:06   #64 (permalink)
Member: 56335
Thanks Meter: 25
Then the scheme from Aamir Zia is wrong, cause the Rx is in the middle of plug, and on the T191 the Tx is in the middle, and I have unlocked many T191 with this cable!
Old 07-16-2004, 09:24   #65 (permalink)
NELU-GSM's Avatar
Member: 9411
Thanks Meter: 16
cable is the same like t191 ,i make a lot of t191 , my x60 is conected with that cable ,prog said unlock ok but phone not unlock
Old 07-17-2004, 05:08   #66 (permalink)
greyz's Avatar
Member: 41325
Thanks Meter: 3
NELUGSM
Is it mails you want or money? if you have it put it out for a price, or you can as well post it here since you prefer the mails, you will get lots of thank you posts
Old 07-17-2004, 08:04   #67 (permalink)
NELU-GSM's Avatar
Member: 9411
Thanks Meter: 16
Greyz,read Very Carefully What I Wrote.
The Cable Is The Same Like T191 But I Cant Unlocked With This Prog,because
Dont Make All Version
My Problem Is The Prog Not The Cable
Find Pinout By Bruce To See Cable For T191!
Regards!
Old 07-17-2004, 19:54   #68 (permalink)
Member: 68959
Thanks Meter: 16
hi all of you,
I've g60 with white screen no function no power off with switch.
not enter in testmode also. i want to know its hardware problem or software ?
pls help me.
thanks
Old 07-17-2004, 20:53   #69 (permalink)
Member: 12504
Thanks Meter: 10
Originally Posted by Rajgreat
hi all of you,
pls help me.
thanks
tri to flash it first if soft probleme than can work.
Old 07-17-2004, 21:04   #70 (permalink)
x60
Member: 69086
Booting phone ...OK.
Phone Imei : 35184700099546
Firmware : GAX60A38.L231.P101
Date : Jan 25 2004
Unlocking phone ..OK
vers 42 M, phone not unlocked!!!
Old 07-18-2004, 14:18   #71 (permalink)
Member: 7632
cable is t191,i unlock all the versions using it...
Old 07-22-2004, 11:38   #72 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 459
QUOTE=Rajgreat]hi all of you,
pls help me.
thanks[/QUOTE]
I also have the same Pronb
I have 1 G60
On With White Light
I know its Software
But I can't Find its Downloader & Flash Files !!!
Anyone have !!!
Old 07-22-2004, 11:47   #73 (permalink)
hekker's Avatar
Member: 33290
i think it's software problem i had same problem in x60 was not hardware problem
Old 07-22-2004, 13:29   #74 (permalink)
reo
reo's Avatar
Member: 4270
Thanks Meter: 13
hi
does any no how to do x60 on the Griffin Team logger ?
i cant get the phone to connect, but with the other douhal software it connects.
help
reo
Old 07-22-2004, 14:21   #75 (permalink)
Member: 12504
Thanks Meter: 10
wen you use griffin loger no need to enter test mode : loch loger inter password , connect your phone and start wen you see power on just impultion with on/off
x60 destroied by ****** x60-x66 george gsm Panasonic 1 08-30-2005 19:13
Panasonic x60 - x66 ALL Versions Unlock Clip aj1rtd Main Sales Section 0 07-24-2004 12:57
Panasonic x60 / x66 ALL Versions Unlock Clip RealNijntje Main Sales Section 0 07-21-2004 10:01
Unlock Your Sagem/LG/NEC/X60/X66/G60/G51/Sewon Free :) makona Main Sales Section 0 07-18-2004 06:32
*** Panasonic X60 X66 unlock clip Invisible Main Sales Section 0 06-23-2004 09:57
Page generated in 0.40515 seconds with 9 queries
