Panasonic Panasonic-News... |
08-01-2001, 16:51 | #1 (permalink) |
Freak Poster Join Date: May 2001 Location: Indian Ocean Age: 54
Member: 4765 Status: Offline Thanks Meter: 0 | GD50 Dead How to repair it ? Thanks |
08-12-2001, 18:45 | #2 (permalink) |
Member: 4765 Status: Offline Thanks Meter: 0 | I have possibility to have another GD50 (maybe not the same version), could i read any bin file from the new and write it onto the dead gd50 ?<br />Thanks |
08-12-2001, 19:25 | #3 (permalink) |
No Life Poster Join Date: May 2000 Location: Russia Moscow Age: 59
Member: 1408 Status: Offline Thanks Meter: 39 | Hi Use full charged battery <br />Flash phone with A09<br />Write correct IMEI & Serial number<br />with Viknet1.1 But I'm affraid after use bad zoran software<br />your phone will have "call limit"<br />activated WBR<br />Crew [QUOTE]Originally posted by rayback:<br />[QB]Hi All,<br />I unlocked GD50 v.a08 with andromeda and zoran 1.02 unsuccesfully. So I use the repairing & [ 12 August 2001: Message edited by: Crew ]</p> |
08-15-2001, 18:31 | #6 (permalink) |
VIP-Member Join Date: Nov 2000 Location: azaz arshad
Member: 2605 Status: Offline Thanks Meter: 0 | Today I had the same problem.Killed GD50 A14 by Andromeda. I read this solution in old Topic and it works for me 100% (after 30 min <img src="biggrin.gif" border="0"> )Don`t know if you have same problem as me but maybe this would help u.Sorry I don`t remember author but it works , many thanx Use GD30/50 repairer by Viknet and follow this instructions:.RUN program "GD50 repair&unlock by viknet v1.0 "<br />2.press "set test mode" and ON phone..phone goes test mode..<br />you will see IMEI and SERIAL..you can enter any ...<br />for example<br />IMEI : 555555555555555<br />SERIAL:IIIIIIIIIIIIII<br />3. press "Repair and Unlock"<br />you will see again warning message.. repeat this steps Until you see IMEI: FFFFFFFFFFFFFF0<br />SERIAL:yyyyyyyyyyyy that is very important..<br />at this point you will enter IMEI : 449121882548521<br />SERIAL : 125005687236501 ( not magic numbers just fit) and press "Repair and Unlock"<br />phoen lights will up..and nothing on the screen..<br />press keys..and lights still ON..<br />keep about 2-3 minutes of this position..<br />(keep pressing keypad,linghts ON and nothing on the screen..)<br />4. after 2-3 minutes OFF the phone and ON again..THAT'S ALL.. <br />Best regards ToTo <img src="wink.gif" border="0"> |
09-03-2001, 18:44 | #7 (permalink) |
Member: 4765 Status: Offline Thanks Meter: 0 | Hi, I was in holidays and now I come back<br />I tried this method unsuccessfully, because when i repair with NEO, the process stops at about 65%<br />and then nothin ... Who has another idea ?<br />Thanxs for your replies Regards, <br />1.RUN program "GD50 repair&unlock by viknet v1.0 " 2.press "set test mode" and ON phone..phone goes test mode..<br />you will see IMEI and SERIAL..you can enter any ...<br />for example IMEI : 555555555555555 (you don't need change original IMEI)<br />SERIAL:IIIIIIIIIIIIII ( this is important only 14 "I") 3. press "Repair and Unlock"<br />you will see again warning message.. repeat this steps Until you see (~ 11- 13 x Unlock & Repair) IMEI: FFFFFFFFFFFFFF0<br />SERIAL:yyyyyyyyyyyy that is very important..<br />at this point you will enter IMEI : 449121882548521<br />SERIAL : 125005687236501 and press "Repair and Unlock"<br />phoen lights will up..and nothing on the screen.. Phone is dead now & you can repair this with NEO Unlocker & Restorer v7.3 Phone is LIVE & Unlocked but have another IMEI. |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
dead GD50 | weri | Panasonic | 0 | 02-19-2003 19:00 |
Panasonic GD50 DEAD | GYZMO | Panasonic | 4 | 08-28-2002 21:37 |
Dead GD50 | frigor1 | Panasonic | 2 | 02-18-2002 23:04 |
dead gd50 | ARt | Panasonic | 0 | 03-13-2000 10:38 |
