Panasonic Panasonic-News... |
06-17-2003, 09:22 | #1 (permalink) |
Junior Member Join Date: May 2003 Location: uk Age: 46
Member: 28415 Status: Offline Thanks Meter: 0 | crack2d unlocks eeprom both gd67/87 a22 or below works even if your sim is already unlocked no need for panaclient 100% has anyone got a53 or a51 yet Last edited by fullfocus; 06-17-2003 at 10:24. |
06-17-2003, 11:19 | #4 (permalink) |
Member: 28415 Status: Offline Thanks Meter: 0 | re eeprom no u downgrade unlock sim and eeprom with a program called crack2d.exe then u can upgrade back up to whatever firmware that u have i think the software is from spunlock.com worked for both of mine U DONT NEED TO DOWNGRADE GD67 ONLY GD87 |
06-17-2003, 12:18 | #6 (permalink) | |
Junior Member Join Date: Apr 2003
Member: 25775 Status: Offline Thanks Meter: 0 | Re: crack2d unlocks eeprom both gd67/87 Quote:
06-17-2003, 14:39 | #8 (permalink) |
Member: 28415 Status: Offline Thanks Meter: 0 | RE its all done by the program with a data cable u have to cover pins like on cb2000 its exactly the same process as panareader v5.0 but it works out the unlock code and unlocks the eeprom in the process it will tell u the code then u enter it in the phone |
06-17-2003, 18:45 | #11 (permalink) |
Junior Member Join Date: Mar 2003
Member: 24820 Status: Offline Thanks Meter: 0 | PIns are covered . I tested it with CB2000. And the USB cable driver emulates automaticly com3 so I can't change the port. Isn't there another way my sim isn't locked only the EEProm? |
06-18-2003, 03:50 | #15 (permalink) | |
Junior Member Join Date: Jan 2003 Location: Sweden Age: 41
Member: 20579 Status: Offline Thanks Meter: 0 | Quote:
then scroll down to your "ports" here you should find "MAT USB-to-Serial Bridge.. rightclick this and properties and then port settings and then you can change to com1 through here.. Ps. If u already have a "physical com1 port" then u can deactivate this and then u have the com 1 free to use with the mat usb blabla.... Good luck! | |
DB2000 unlocked eeprom with padref tool - STRANGE problem | MovilCom | Various | 0 | 05-15-2002 19:10 |
Samsung R210s unlocked eeprom needed | jonwillow | VLSI, Conexant, Skyworks and Old Models | 1 | 04-19-2002 06:28 |
WinDDP 300 released ! IMEI, 4 LOCKS UNLOCK, EEPROM REPAIR | codec_romania | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-15-2002 07:49 |
Need Locked or Unlocked eeprom samsung r200 | maxximm | VLSI, Conexant, Skyworks and Old Models | 0 | 11-08-2001 00:38 |
where to find "FREE UNLOCKER EEprom 1.65 by [--== Lovelas '99 ==--] " ? | dofie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-21-2000 17:37 |
