Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 02-21-2005, 19:23   #1 (permalink)
Member: 61178
Unhappy Panasonic A100 problems
Hi,
I've got a panasonic a100 and the phone does wierd stuff.
The battery doesnt work good if i charge like 21 hours i can start the phone but it goes off again after showing the panasonic logo.
Now the phone doesnt goes on anymore.
What can this be, i hope someone can tell me whats the problem.
Mr
Old 02-21-2005, 23:39   #2 (permalink)
te
Member: 2357
Thanks Meter: 4
Press and hold Red buton several seconds until phone totally start.
Old 02-22-2005, 12:22   #3 (permalink)
Member: 61178
yeah ok i did that. Nothing happens but logo and then its off again.. ( logo stays for a few seconds )
Old 02-22-2005, 12:39   #4 (permalink)
Member: 26066
Sonork: cooleyes
Thanks Meter: 128
have you tried it without sim if its say insert sim the solution is open the phone remove backup battery for 5min and again switch on the phone and post result
Old 02-22-2005, 20:22   #5 (permalink)
Member: 61178
ok ill try tomorrow.
I havent got the equipment here to open the phone.
Thnx in advance
Old 02-22-2005, 21:15   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 436
Solution is Easy
Check with other Charge battery
Phone will Now on & Hang on panasonic logo when Sim inserted
Then manually enter reset Code Without SIM
Phone will be OK
Old 02-23-2005, 14:10   #7 (permalink)
Member: 61178
whats the reset code? dont know where 2 find
Old 02-23-2005, 14:15   #8 (permalink)
Member: 61178
@cooleyes i removed the batt and put it back.
the phone worked for 5 minutes then same problems
Old 02-23-2005, 14:29   #9 (permalink)
Member: 61178
Its very difficult solution/
Solution is more simple:
Just enter *01763*737381# without sim !!!!
Works 100%
When you remove battery, you do the same: reset eeprom ......
found in other topic?? i did this looks like now ok
Old 02-23-2005, 15:17   #10 (permalink)
Member: 61178
phone boots logo comes use my pin and then it works but after like 10 minutes the phone hangs
Old 02-27-2005, 10:40   #11 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Thanks Meter: 3,716
write flash it will be ok
Old 02-27-2005, 23:05   #12 (permalink)
Member: 109326
you need to reload the software, same as the ph does not read sim & sometimes no network problems.
Old 03-02-2005, 12:47   #13 (permalink)
ramcellular's Avatar
Member: 121974
Thanks Meter: 82
hi friends problem with panasonic A100 vibrating automatically when call connected and when i pressed on speaker it is getting connected to vibration. solution pls.
Old 03-03-2005, 02:29   #14 (permalink)
Member: 106244
http://www.gsm9d.com.tw/bbs/list.asp?boardid=60
A100
Old 03-07-2005, 14:48   #15 (permalink)
tatalko's Avatar
Member: 32002
Thanks Meter: 22
Works 100%
............................this work 100%................................
Panasonic A100 hv problem to UNLOCK - URGENT khem Infinity-Box 9 06-17-2008 18:41
panasonic A100 Mic problem hooi76 Hardware Repair by brands 1 02-15-2007 15:51
Panasonic A100 Display Problem gsmsikar Panasonic 7 08-31-2005 07:00
Panasonic A100/g50 flashing problem Moosani Panasonic 8 10-07-2004 08:00
Mr. Te come back. Panasonic A100 Russian language flasher and more... te Main Sales Section 0 05-02-2004 12:54
Page generated in 0.37215 seconds with 8 queries
