Panasonic Panasonic-News... |
04-08-2004, 19:49 | #1 (permalink) |
Junior Member Join Date: Apr 2004
Member: 61125 Status: Offline Thanks Meter: 0 | Panasonic G51 Ringtone Size? "Error: Document too large" I am aware that there is a 30 kB max file size. I get the error message with files of 10kB. I have also added the following mime setting in IIS: application/vnd.smaf I was wondering is there some wml code I need to add that tells the phone the size of the file? |
04-09-2004, 09:32 | #2 (permalink) | |
Junior Member Join Date: Mar 2004 Location: Gothenburg, Sweden Age: 54
Member: 58990 Status: Offline Thanks Meter: 0 | Quote:
I did exactly the same. And got exactly the same problems. Then I tried minimizing the total size of the wml-document and suddenly it worked to download ringtones <30kb. Btw....I've added alot of different mime-caracters to the document, just in case. Here they all are: .gif = image/gif .jpg = image/jpg .mid = audio/midi .au = audio/basic .snd = audio/basic .bmp = image/bmp .wav = audio/x-wav .hdml = text/x-hdml .pcm = audio/32kadpcm .qcelp = audio/vnd.qcelp .wml = text/vnd.wap.wml .mmf = application/vnd.smaf .wbmp = image/vnd.wap.wbmp .wmls = text/vnd.wap.wmlscript .wmlc = application/vnd.wap.wmlc .wmlsc = application/vnd.wap.wmlscript Keep trying, I know it worked for me..... /Televinken | |
04-09-2004, 19:43 | #3 (permalink) |
Member: 61125 Status: Offline Thanks Meter: 0 | Could you post your wml code? Here's mine: <?xml version="1.0" encoding="iso-8859-1"?> <!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML 1.3//EN" "http://www.wapforum.org/DTD/wml13.dtd" > <wml> <card> <p><a href="ahello.mmf">MMF</a></p> </card> </wml> |
04-09-2004, 20:53 | #4 (permalink) |
Member: 58990 Status: Offline Thanks Meter: 0 | <?xml version="1.0"?> <!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML 1.1//EN" "http://www.wapforum.org/DTD/wml_1.1.xml"> <wml> <card id="MainCard" title="Televink-wappen"> <img src="televink.gif" alt=" "/> <do type="accept" label="Pictures"> <go href="pictures.wml"/> </do> <do type="accept" label="Ringtones"> <go href="ringtones.wml"/> </do> </card> </wml> |
04-10-2004, 21:23 | #6 (permalink) |
Member: 58990 Status: Offline Thanks Meter: 0 | <?xml version="1.0"?> <!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML 1.1//EN" "http://www.wapforum.org/DTD/wml_1.1.xml"> <wml> <card id="ringtones.wml" title="Ringtones"> <do type="accept" label="*******"> <go href="*******song.mmf"/> </do> <do type="accept" label="Rape"> <go href="rapesong.mmf"/> </do> </card> </wml> /Televinken |
04-11-2004, 05:46 | #7 (permalink) |
Member: 61125 Status: Offline Thanks Meter: 0 | Thanks for posting the code. I tried it and it still didn't work... I'm still getting the "Document too large" message. The wml document is 1kB, and the mmf document is 8 kB. Help! The same thing happens with Midi files. I've also tried using Apache, but no luck. |
04-11-2004, 10:09 | #8 (permalink) |
Member: 58990 Status: Offline Thanks Meter: 0 | Sorry it didn't work out well for you. It works fine for me with the code above. However, when a friend of mine try to access the wap-page, he just gets the message;unrecognized fileformat. He uses a Nokia 6820, but I don't know if that's the problem. But hey, why don't you try my wap-site, & see how it goes? Pm me in private, so I can give you the address. /Televinken |
04-13-2004, 19:26 | #10 (permalink) |
Member: 58990 Status: Offline Thanks Meter: 0 | Sure is. Don't ya have the manual, dude..? Menu -> Applications -> Sound/Pic folder -> Memory status.......then you're done.... /Televinken |
panasonic G51 phone lock code needed! | orefice.matteo | Phone Unlocking Codes & Maps | 22 | 10-21-2004 06:48 |
***PANASONIC G51 - How to Unlock this phone ?*** | FuriouS TeaM | Panasonic | 48 | 07-11-2004 13:55 |
*****All Nec Code Reader + Panasonic G51 Calc + Panasonic G60 = 200 Euros **ZONEGSM** | FuriouS TeaM | Main Sales Section | 0 | 06-18-2004 11:23 |
phonecode locked panasonic G51 | Ibran | Panasonic | 0 | 04-06-2004 19:30 |
Panasonic g51/x66/g70 org software | yungcable | Wanted Products | 0 | 03-02-2004 21:52 |
