Panasonic Panasonic-News... |
09-04-2001, 19:02 | #2 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Australia Age: 41
Member: 3671 Status: Offline Thanks Meter: 28 | Hi,<br />try to flash it and then unlocked. Maybe the problem is solved. 100% working solution buy a panasonic gd52,92,93 clip and use this, works faster and safer.<br />Good luck,<br />Alro |
09-09-2001, 20:54 | #5 (permalink) |
Junior Member Join Date: Sep 2001 Location: Hungary
Member: 6167 Status: Offline Thanks Meter: 0 | Hi, F4 - Lock condition (view lock code) <img src="cool.gif" border="0"> Download:<br /><a href="http://www.freeweb.hu/pinker/channelbox/gd52_92_93channelbox.zip" target="_blank">http://www.freeweb.hu/pinker/channelbox/gd52_92_93channelbox.zip</a> Pinker... |
05-14-2002, 03:27 | #7 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Romania Age: 41
Member: 11445 Status: Offline Thanks Meter: 0 | HELP! Hi Ikk! I saw your post and you can verry easy resolve your problem using Chan box for Panasonic GD52, 92. Check your mail! I need a info from you after you see the keyboard look code, I have too a GD-52 but my phone is factory reset and I want to look with chan box pressing F7 after that select trim others (no harm to your phone) and to tell me al the all the values from that windows. Please help! I wait for your answer! |
05-19-2002, 05:42 | #8 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Novosibirsk
Member: 6791 Status: Offline Thanks Meter: 0 | I use gd92&gd93chbxs.exe for reading GD95 - but without success How can I remove keyboard lock from this phone? maybe my pinouts is wrong? It is the same as GD93? Or it is different? |
05-20-2002, 14:13 | #9 (permalink) |
Member: 11445 Status: Offline Thanks Meter: 0 | RE: Did you make 1-5 connections? You told that you have an GD52. The pins 1 and 14 are the same. They are GND. After you connect the phone (phone is off) start chan box enter to test mode, the first option of the menu, and press enter.After that press F10 and will say to turno on the phone. Press quick the power button of the phone and it must read the phone. Check connections! |
Panasonic Gd52 Keypad Is Lock Need 2 Unlock It Dont Know Much About This | TJ.HOOKS | GSM Programming & Reverse Engineering | 1 | 01-17-2004 20:36 |
GD52 Keyboard lock | cianyika | Panasonic | 2 | 10-01-2003 02:05 |
Exchange..I have panasonic GD52/92/93 unlocker,lang.flasher,full EMMI sw,sheme... | michael57 | x1x to x45/x50 | 0 | 03-06-2001 22:38 |
Exchange...I have Panasonic GD52/92/93 unlocker and lang.flasher,full EMMI sw,sheme.. | michael57 | Exchange Section | 0 | 03-06-2001 22:36 |
How to unlock keyboard lock on Panasonic G520? | MaRiN | Panasonic | 0 | 11-19-2000 22:17 |
