panasonic p-55 strange issue hi i have panasonic P-55 model which is hang on logo ,i flashed this phone with file " Panasonic_P55_4.4.028.P3.141231.7298D_I01_" flash success 100% but after power on phone starts goes on first screen logo then with blank screen shows " 1/1. Modem Up and Down" can anybody guide me for this issue? also tried this ver but flash fails at start -(Panasonic_P55_4.4.021.P1.141118.7298D_I01) http://i1264.photobucket.com/albums/...psrkq3rsbk.jpg thank you |
Dev-Host - Factory mode fix by Pinto.zip - The Ultimate Free File Hosting / File Sharing Service downlode this file bro and do this job 1000% done ur set on in normal mode... 1. Download and extract all the Files in a folder that's easy to find 2. On ur Phone then connect it to a PC 3. Open cmd to run as administrator 4. type- adb shell 5. Type- Quote: -b fctd normal or fctest system reboot 6.Press Enter 7. Phone will restart automatically, 8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal br ashish singh |
great ashish singh thank you so much i was thinking last way to send customer to service centre but you did my job http://i1264.photobucket.com/albums/...psudnkbifp.png thank you once again |
not working salution |
ramrajbhopal this working solution you need to copy and paste above command correctly you may be need pc restart if it fails though you gave correct command , i faced so keep patience and try goodluck |
unFactroy Mode.bat how to download this file |
copy first line of ashishsingh post and search in google you will find all |
check the volume keys waseem raja |
hi i had the same issue earlier before trying this wht i did is i tried with a sp tool scatter file now its on logo then off then again i tried to flash with ygdp tool now flashing always stops with 75% kindly revert if anyone having a solution |
Device Not Found...in adb shell...., Device Manager Detected And Show"CMCC Composite ADB Interface"....... Thanks.... |
Not Solved...:confused:http://i65.tinypic.com/2hqxqp1.jpg |
problem solved with http://forum.gsmhosting.com/vbb/f811.../#post11565894 |
