Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 06-08-2015, 11:32   #1 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
panasonic p55 flashing problem
i was fail to flash PANASONIC P55 with ygdp tool
it fails on 98% every time
any one face this issue
if yes pllss report me the solution
15:58:22 CELL0: Verify is Partition be Changed.
15:58:22 CELL0: Partition is Changed.
15:58:22 CELL0: Get Usb Status Success.
15:58:22 CELL0: Read YL-Parames Partition Start.
15:58:24 CELL0: Read YL-Parames Partition Success.
15:58:24 CELL0: Check between YL-Parames Partition and PhoneInfo Start.
15:58:24 CELL0: Check between YL-Parames Partition and PhoneInfo Failed.Error Code:18
15:58:24 CELL0: Check YL-Parames Partition Failed, The CPB is not for the Phone.
15:58:24 CELL0: DisConnect.
15:58:44 CELL0: Total download time elapsed: 0 min : 25 sec
15:58:44 CELL0: Downloading CPB: Failed!
The Following User Says Thank You to sharpgsm For This Useful Post:
Old 06-27-2015, 18:03   #2 (permalink)
Cheater -Don't Deal with him-
Member: 2388887
Sonork: 100.1623070 QQ 3208774531
Thanks Meter: 1,202
hello
sam process as p81
here is step by step flashing procedure
p81 same as p55
dont forget press only thanx button
The Following 2 Users Say Thank You to abhayranasingh For This Useful Post:
Old 06-28-2015, 05:14   #3 (permalink)
Member: 1874043
Sonork: 100.1624410
Thanks Meter: 3
i try but same 1st file try set flash camplet 100% ok but set not on 2nd ver..file write 98% falid how to solive.....plzz help me....p51
Old 06-28-2015, 05:41   #4 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
Originally Posted by abhayranasingh View Post
hello
sam process as p81
p81 same as p55
bro i was already check that post but after that procidure my set fails at 98%
Old 06-28-2015, 06:18   #5 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
Pansonic P81 Flashing Flashing Procedure Here
Old 06-28-2015, 07:52   #6 (permalink)
Member: 2388887
Thanks Meter: 1,202
I think your phone is hardware problem
because 1 done maney handset this model
thanx
br,
abhayranasingh
Old 01-19-2016, 08:54   #7 (permalink)
Member: 2310475
Thanks Meter: 64
panasonic p 55 98% flashing error ............
Old 02-02-2016, 17:46   #8 (permalink)
Member: 974006
use other ver
flash file
Old 02-07-2016, 08:44   #9 (permalink)
Member: 960720
Thanks Meter: 8
i used other ver.,flashing done but after on showas only up and down
Old 03-02-2016, 09:56   #10 (permalink)
raju2's Avatar
Member: 455407
Thanks Meter: 14
Same with me after flash show only volume up and down any soultion ple
Old 03-02-2016, 13:16   #11 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
1.Connect phone to PC
2. Start Menu - Run, type: cmd and hit Enter
3. Type: cd/
4. Type: adb shell fctest system reboot and hit Enter
The Following 3 Users Say Thank You to habeebkambrath For This Useful Post:
Old 03-02-2016, 14:25   #12 (permalink)
Member: 2069837
Thanks Meter: 17
3. Type: cd/
thanx broooo my problem solve
The Following User Says Thank You to shahrukhkhan904 For This Useful Post:
Old 03-10-2016, 11:32   #13 (permalink)
raju2's Avatar
Member: 455407
Thanks Meter: 14
3. Type: cd/
error:device not found after do this commond help ple
Old 03-10-2016, 13:37   #14 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
condition of the handset now?
The Following User Says Thank You to habeebkambrath For This Useful Post:
Old 03-10-2016, 14:10   #15 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
first check your device manager phone connected via adb mode or not?
if connected ,then type in adb&fastboot command window
br,
habeeb kambrath
Page generated in 0.22793 seconds with 8 queries
