Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 07-14-2014, 15:18   #16 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Originally Posted by amit_varietymob View Post
Moulnisky is showing wrong password.. Please provide password sir.. As none of above hard reset procidure is woring on my set.. Thanks in advance..
Moulnisky copy paste hare only working
Old 07-14-2014, 15:20   #17 (permalink)
Member: 2091636
not working plz any other solution
Old 07-14-2014, 15:24   #18 (permalink)
amit_varietymob's Avatar
Member: 399228
Thanks Meter: 66
Yes brother Tejaram got password but after copy paste.. A drive is always busy.
The Following User Says Thank You to amit_varietymob For This Useful Post:
Old 08-09-2014, 13:35   #19 (permalink)
Member: 786547
Sonork: 100.1645883
Thanks Meter: 8
For panasonic T21, If nothing Works as stated by the members then
Connect ur volcano, go to android, tick adb root then phone will be rooted then reset gmail.
hold phone and press power button it will take adb android drivers then do above process.
Remember dont long long press power button...
The Following User Says Thank You to serajloves For This Useful Post:
Old 08-14-2014, 17:31   #20 (permalink)
Member: 2240320
i want a flash file for the panasonic t21. can anyone help me?
Old 08-23-2014, 11:17   #21 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
thanks its woking ...
Old 09-12-2014, 13:28   #22 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
I Am Try All Method But I Am Not Sucessfule
I NEED FINAL SOLUTION..................
Old 09-13-2014, 14:34   #23 (permalink)
Member: 2256867
it is impossible to make a hard reset
Old 10-01-2014, 13:40   #24 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
fake salusan broooooooooooooooo
Old 10-01-2014, 13:41   #25 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
Panasonic t21
Old 11-24-2014, 15:04   #26 (permalink)
Member: 183851
Sonork: 100.105150
Thanks Meter: 19
work for me thanks....
Old 01-27-2015, 09:13   #27 (permalink)
Member: 1348454
Thanks Meter: 6
Panasonic t21 pattern lock done....
Old 01-30-2015, 07:50   #28 (permalink)
Member: 1054903
Thanks Meter: 4
Just Flash your phone with this file and procedure
Welcome to the ./downloads/Panasonic/T21/ folder of GsmHosting support area
Download "BRCM_WinUSB_ADB_Jungo_MTP_RNDIS_Driver_1.05.z ip"
and install the Driver
Download "Brcm_MultiDownloader_1450rc.zip"
Extract
Open "MultiDownloader.exe"
click "configuration"
Select folder Location "android_cg_0x1_ktouch_kb_secure"
Select Diag Port "1"
Your Driver must show as "Broadcom usb Download Device" if it shows any port number then won't work
Press "apply"
press "start"
remove battery
connect usb on the phone ## must not through hub ##
insert battery
it automatically detect and run
if you don't find the files just copy each name and search one by one on google
Old 01-30-2015, 21:53   #29 (permalink)
Member: 1054903
Thanks Meter: 4
Eazy way to flash
a. Install Driver:
- Open "BRCM_WinUSB_ADB_Jungo_MTP_RNDIS_Driver_1.05" folder. Run the .exe file to install driver.
b. Open flashtool folder Brcm_MultiDownloader_1450
- Run "MultiDownloader.exe" programe
c. Choose Settings > Configuration
Click to [...] button and choose the SW folder
d. Choose Download Mode “Upgrade (Keep Factory data) then click Apply
e. Click Start
f. Turn your phone off, remove the battery
g. Insert USB cable then Insert battery
h. Check driver if the Flashtool do not start
Good luck !
Old 02-12-2015, 19:53   #30 (permalink)
Member: 1885999
Thanks Meter: 8
every step is fake.....
But its challanging and intresting
100000000000%% sollution
Switch Off your mobile and connect to pc and make usb and ADB Driver
1st use Volcano v2.9.0
2nd click on Android tab
3rd go to adb mode
4th tick on ADB root
5th click on start
after all step your phone is successfully Rooted
Now its magic
6th now tick on reset Gmail option and run.......10000000% success unlock ur phone
make thank
The Following User Says Thank You to ali.wadiwala For This Useful Post:
Page generated in 0.22972 seconds with 10 queries
