Panasonic Panasonic-News... |
08-09-2014, 13:35 | #19 (permalink) |
Insane Poster Join Date: Jun 2008 Location: visakhapatnam
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | For panasonic T21, If nothing Works as stated by the members then Connect ur volcano, go to android, tick adb root then phone will be rooted then reset gmail. hold phone and press power button it will take adb android drivers then do above process. Remember dont long long press power button... |
The Following User Says Thank You to serajloves For This Useful Post: |
08-23-2014, 11:17 | #21 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
01-30-2015, 07:50 | #28 (permalink) |
Insane Poster Join Date: Jun 2009 Location: chennai
Member: 1054903 Status: Offline Thanks Meter: 4 | Just Flash your phone with this file and procedure Welcome to the ./downloads/Panasonic/T21/ folder of GsmHosting support area Download "BRCM_WinUSB_ADB_Jungo_MTP_RNDIS_Driver_1.05.z ip" and install the Driver Download "Brcm_MultiDownloader_1450rc.zip" Extract Open "MultiDownloader.exe" click "configuration" Select folder Location "android_cg_0x1_ktouch_kb_secure" Select Diag Port "1" Your Driver must show as "Broadcom usb Download Device" if it shows any port number then won't work Press "apply" press "start" remove battery connect usb on the phone ## must not through hub ## insert battery it automatically detect and run #################### if you don't find the files just copy each name and search one by one on google |
01-30-2015, 21:53 | #29 (permalink) |
Member: 1054903 Status: Offline Thanks Meter: 4 | Eazy way to flash a. Install Driver: - Open "BRCM_WinUSB_ADB_Jungo_MTP_RNDIS_Driver_1.05" folder. Run the .exe file to install driver. b. Open flashtool folder Brcm_MultiDownloader_1450 - Run "MultiDownloader.exe" programe c. Choose Settings > Configuration Click to [...] button and choose the SW folder d. Choose Download Mode “Upgrade (Keep Factory data) then click Apply e. Click Start f. Turn your phone off, remove the battery g. Insert USB cable then Insert battery h. Check driver if the Flashtool do not start Good luck ! |
02-12-2015, 19:53 | #30 (permalink) |
Insane Poster Join Date: Feb 2013 Location: INDIAN
Member: 1885999 Status: Offline Thanks Meter: 8 | every step is fake..... But its challanging and intresting 100000000000%% sollution Switch Off your mobile and connect to pc and make usb and ADB Driver 1st use Volcano v2.9.0 2nd click on Android tab 3rd go to adb mode 4th tick on ADB root 5th click on start after all step your phone is successfully Rooted Now its magic 6th now tick on reset Gmail option and run.......10000000% success unlock ur phone make thank |
The Following User Says Thank You to ali.wadiwala For This Useful Post: |
