Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 10-09-2004, 07:28   #1 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
PANASONIC X60 Flasher need :((
NEED x60 flashing.. very Important.
I have one X60 from 3months.. and need to repair.
Its having Restart problem...
Br.
Wahab
Old 10-24-2004, 17:45   #2 (permalink)
Member: 64089
Thanks Meter: 19
Br.
Wahab
hi www.pana-extreme.net
Old 10-25-2004, 10:00   #3 (permalink)
Member: 34054
@einstien
Interesting product, how much ?
Old 10-25-2004, 18:10   #4 (permalink)
giorgi2002's Avatar
Member: 12524
Thanks Meter: 3
http://xak.pp.ru/ have good software tested and good work
Old 10-27-2004, 10:43   #5 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 226
Br.
Wahab
You can download flasher for X60 here:
http://www.unlockeasy.com/modules.ph...titleA&show=10
Its called Panasonic X60 beta test v0.88c by Terror. t Reads and writes flash, on all versions, and also reads and writes eeprom. if you need a X60 flash, just write me back and ill give you the link. Ive flashed many X60 with this, and working 100%
Hope this helps you!
Old 10-27-2004, 13:39   #6 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
this work anly with old versions
Old 10-27-2004, 18:35   #7 (permalink)
Member: 37610
PLS M. Bi0H4z4rD I NEED KEY
THX
Old 10-28-2004, 21:22   #8 (permalink)
softmaster's Avatar
Member: 57871
Sonork: 100.74800
Thanks Meter: 6
any direct link to download x60 flasher+flash file ??
Old 10-29-2004, 12:49   #9 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 226
This sw works with ALL versions. You dont need any key, just run loader.exe under win98 and it will be ok. Flash file, the only one i have is A34. If someone still want the flash file, just write me back, else, remember you can read flash file from another x60 with that sw.
Old 10-29-2004, 18:53   #10 (permalink)
Member: 77697
Bi0H4z4rD, to flash the X60, you're using the normal T191 cable or the modded cable with +9v alimentation?
Many thanks.
Old 10-29-2004, 19:44   #11 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
did this work for you??
because nobody on this forum can flash with this flasher.
Old 10-29-2004, 20:56   #12 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
This Soft Not works
I have also 1 Piece of X66 have restart Prob ( say FAILED & reset )
This Terror Soft Gives Error 10 ....
I also need its Solution very URGENT
Old 10-29-2004, 21:04   #13 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Originally Posted by Aamir_Zia
This Soft Not works
don't waist your time,propably you can't enter to test mode and that means you can't flash it.if you find the way for manual format for user area then problem will fixed without flashing
Old 10-30-2004, 11:21   #14 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 226
To enter test mode you just need to hold down three keys, no sw is needed, so it has nothing to do with this
To others:
I did flash using t191 cable compatible with x60 (with +9v), win98 SE, on a laptop with one COM port. anyway ill try to find out why couldnt u flash or whatever and try to find another flasher, but this one DID work for me. Ill post screenshots as soon as i get another X60 to flash.
Old 10-30-2004, 11:32   #15 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
yes we know that(there isn't other way) and i mean propably he can't enter to test mode pressing this 3 keys.
Panasonic X60 Flasher afacandenis Panasonic 1 09-16-2004 20:54
panasonic x60 flasher rw21914 Panasonic 9 08-20-2004 18:13
----- Panasonic* X60 Flasher 100 EUR ----- farrell Main Sales Section 0 08-18-2004 02:10
x60 flasher!!!!!needed celox Panasonic 4 06-26-2004 03:02
panasonic x60 unlocker need your experience megone Panasonic 12 06-09-2004 01:23
Page generated in 0.20087 seconds with 9 queries
