Panasonic Panasonic-News... |
08-03-2003, 19:35 | #1 (permalink) |
Junior Member Join Date: Aug 2003
Member: 36336 Status: Offline Thanks Meter: 0 | PLS HELP. blinking screen after flashing GD87 Thanks popaz |
08-03-2003, 19:46 | #2 (permalink) |
Junior Member Join Date: Apr 2003
Member: 27269 Status: Offline Thanks Meter: 0 | don't worry, it will be fine. When using CB2000 first make sure the coom port settings are allrigght. Then, very important, insulate pin 4 and 10 from your connector!! when connected with cb2000, goto write handset, settings, press "function clear-memory erase" For more a better explanation; http://sky.prohosting.com/~pteal/art...ware/a39.shtml Good luck, it will work!! Greetz, Bassie |
08-03-2003, 20:15 | #4 (permalink) |
Member: 27269 Status: Offline Thanks Meter: 0 | no, I don't know that . When does it happen? when using wap or just now and then. You can try with CB2000 to blank media. ->write handset, blank media. Also press function clear memory erase one more time. If it is still freezing, it must be bad firmware, then you can try to reflash it with other firmware. |
3650 blinks white screen after flash with latest version | mailhassan | WD2 & APE (Symbian Phones) | 13 | 12-19-2008 08:00 |
Pls Help K610i dead after flash | nova_mobil | SETool2 | 13 | 12-16-2008 13:27 |
pls help me..!!6630 after flash phone start-up failer.contect the retailer | ahsam | Nokia Hardware & Hardware Repair | 12 | 05-26-2007 11:14 |
d500 blinking startup screen after flash | livewirecebu | TST Dongle | 16 | 09-09-2005 20:55 |
Pls help blue screen a60 after full flash but work good | visanlg | E-Gold Based Phones | 2 | 12-10-2004 09:02 |
