Panasonic Panasonic-News... |
09-10-2003, 12:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | Problem after flashing GD87! |
09-10-2003, 13:50 | #7 (permalink) |
No Life Poster Join Date: Nov 2002 Location: D U B A I Age: 45
Member: 17651 Status: Offline Sonork: 100.81230 Thanks Meter: 318 | concat phone to cable .open cb2000. (1) select Model (2)click option handset power (3) select data option in uper menu (4) than settings (5) than funcation clear (Memory Erase ) after that check ur phone .it will work fine .. Thanks n Regards |
09-10-2003, 14:17 | #8 (permalink) | |
No Life Poster Join Date: Dec 2001 Age: 56
Member: 7721 Status: Offline Sonork: 100.1598522 Thanks Meter: 23 | Re: Problem after flashing GD87! Quote:
http://www.freegsm.biz/down/panasoni...7/GAD87A22.zip http://www.freegsm.biz/down/panasoni...7/GAD87A21.zip Works fine.Tested by me! | |
09-10-2003, 19:01 | #9 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | thanks to everone for the help Will get the phone back in the morning will post the results. When flashing does the LP have to match the main flash? If so do you have the LP for the files posted above please? |
09-11-2003, 12:00 | #13 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Well I have now flashed it with the above A22 flash and it just flashes as before! Are you sure 100% that the lp doesnt have to match? Because the LP is showing a version in its description? |
09-11-2003, 12:06 | #14 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | The only flashes that work at least on the GD87 I have here now is the A53 one. The other two A21 and A22 just make the phone flash! Has anyone got any other version flashes please? |
5310 problem after flash.Please help for this problem. | caremobiles | Nokia Base Band 5 ( BB-5 ) | 9 | 04-30-2009 15:39 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
PLS HELP. blinking screen after flashing GD87 | popaz | Panasonic | 6 | 08-20-2003 16:47 |
gd87 problem after flashing and unlocking | ryumahon | Panasonic | 4 | 07-28-2003 07:40 |
Display problem after flashing t28s | mashco | Old Ericsson Phones & Sony Phones | 1 | 04-22-2001 14:59 |
