Panasonic Panasonic-News... |
11-21-2000, 23:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | is there really a way to repair a dead GD90 |
11-22-2000, 05:57 | #2 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | hi , which program did you use for flashing ? And after flashing use gd90_7 prog like this. GD90_7 1 -i IMEI You must also correct charging problem. And final thing : Every GD90 doesn't use GAD90B12 , only has AT letters near the simcard holder accept this flash file. Best Regards... |
11-22-2000, 07:16 | #3 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | thanks for your reply, i used Panasonic GD90 B16 solution downloaded from GSMGOD, flsashed it with gad90b12.DAT maybe that was the problem because the phone hat version gad90b 14-0000-13B before flashing and not b16, when i try to flash it now the green light goes on and the flashing process is done but i can not run GD90_7 after flashing because i am asked to turn the phone on and you get a massage like no response from phone or somthing like that, maybe i have used the wrong flash for this phone can any one send me some flash files for GD90 or tell me where i find them thanks |
11-22-2000, 18:40 | #5 (permalink) |
No Life Poster Join Date: Oct 1999 Location: France Age: 46
Member: 570 Status: Offline Thanks Meter: 18 | Hi Dear , I got the same problem...maybe your cable is home made...don't worry just use USPU cracked and flash again your phone/a lot of times if necessary/ Good Luck |
11-22-2000, 23:16 | #6 (permalink) |
Member: 1623 Status: Offline Thanks Meter: 1 | Hi , again. Don't use name "GAD90B12.dat" only "GAD90B12" without extention. 1- First press "1" on the keyboard and then connect cable to the phone.Green light will turn on.Press ESC key to return the main menu. 2 - Press "4" on the keyboard.Then write gad90b12 or c:\xxxxxx\gad90b12 Not : xxxxxx is directory of where your gad90b12 file placed.This file is more than 1 MB long.After flashing , On the monitor , you must see the message "Flashing .... successfull , Press any key to return main menu" 3 - Press "8" key on the keyboard. |
11-23-2000, 00:16 | #7 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | dear Nightxyz after trying to flash the phone with gad90b12, i get this message cannot recciev full Check-Sum indication press esc to return to menu i think i cannot flash the phone properly, do you know what i have to do after getting this message, thanks for your help |
11-23-2000, 15:58 | #9 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | hi i tried nightxyz solution, the problem is that at the end of flashing i get the message: can not receive ful Check-Sum indication instead of getting the message: flashing successfull the cable i am using must be ok because i can unlock gd30 with it and the green ligt on the phone goes on when i start flashing, i don't realy know what the problem is |
11-23-2000, 22:02 | #10 (permalink) |
Major Poster Join Date: Oct 2000 Location: TURKIYE
Member: 2439 Status: Offline Thanks Meter: 0 | hi; i thing your soft installation not true. Because i make some errors like yours when i was unlocking GD90 phones first time and phone died but later i understand that this flash file and setting incorrect.Please control *.bat files and LZH.exe. Simple download (Panasonic GD90 B16 Solution (Tested 100%).zip)from www.gsmgods.net and download B12 flash file too.Unzip this files in a same directory.Be sure that flash in .Lzh format.Because "go.bat" file otomaticly open this lzh file.And control if there in the directory any file with 0KB long. i hope you understand something. if you don't understand i will mail you with pictures. Sorry for bad english. Best Regards. ByteMaster. |
11-23-2000, 22:08 | #11 (permalink) |
Member: 2439 Status: Offline Thanks Meter: 0 | oooops........ i remember something now.Please check the directory location. Because the batch files is use "C:\flash90" or something like this. i say again check the "*.bat" files. |
11-23-2000, 22:40 | #12 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | Thank you Bytemaster at the moment i can not try any more thing because the battery is flat and i can not charge it, i will try to get another battery and try everything again. fortunatelly Crew is helping me as well and has made some suggestion that i will try tomorow and see if we are going to bring the phone back to life. just one question, the phone had originally the version GAD 90B 14-0000-13 B which flash file is the right flash for this phone? i have all the LZH files, which one is the right one? |
11-24-2000, 20:25 | #14 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | dear byte master i have flashed the phone with GAD90B12.LZH lots of time but it doesn't work i still get the Message cannot receive Check-sum indication, i tried it with verify check- Sum the green light goes off but i am still unable to power on the phone, i fully charged the battery today as well so it can't be the Battery, i have almost given it up, because i have tried everything i would like to thank everybody who tried to help |
11-25-2000, 07:24 | #15 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | dear ByteMaster is it possible for you or any other friend who has the File GAD90b12.lzh and has tested it with positive result to send me this file, maybe the one i am using is not working when i have a working GAd9012b may be i can give it a last try |
is there any free way to convert red52 C510 to brown? | ilbefun | Sony Ericsson | 6 | 12-22-2009 08:15 |
Is there an easy way to unlock nokia e71 | donovan2123 | Nokia Base Band 5 ( BB-5 ) | 5 | 06-18-2009 00:37 |
is there a new way to repair eeprom on w370 after flashing | maxheadquarters | Motorola Hardware Repair | 0 | 06-28-2007 06:58 |
is there a special way to boot kg800? | .:GSM International:. | VygisToolbox | 5 | 08-09-2006 12:27 |
