Panasonic Panasonic-News... |
11-25-2000, 14:05 | #16 (permalink) | |
Freak Poster Join Date: Nov 2000 Location: eindhoven
Member: 2654 Status: Offline Thanks Meter: 0 | Quote:
I have the same problem, my GD90 is also dead. i also tried everything, but nothing will work:-( Who can help me with the working programs and flashfile ? I used the programs which named above, but it didn't work. Please help me. You can send any programs to [email protected] Hope you can help me. | |
11-25-2000, 14:23 | #17 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | hi pascal which prog did you use in the first place to unlock yours, i used Perom20 with the wrong flash file, how did it happen with yours, which progs have you tried up to now |
11-25-2000, 19:53 | #18 (permalink) | |
But i hope that someone can send me a program or a flashfile which will work. I can't call know :-( Hope to hear from you soon. tnx. Pascal. | |
11-25-2000, 21:02 | #19 (permalink) |
Major Poster Join Date: Oct 2000 Location: TURKIYE
Member: 2439 Status: Offline Thanks Meter: 0 | hi again; i am using a file that downloaded from www.gsmgods.net (Panasonic GD90 a12 flash file ). i have an idea why you send me this informations: 1-Where is your prog installed. e.g C:\xxxxxx 2-your *.bat files in this directory. 3-a txt that includes files information(DIR>info.txt command) and i look what is the problem. if your phone is not work too. I PROMISE i will send you my folder completely. Connect with me at my ICQ nearly 12:00 or 21:30 ICQ:97107817 Best Regards. ByteMaster |
11-27-2000, 00:27 | #20 (permalink) | |
i contact bytemaster by icq, and hop you can help me also. | |
11-27-2000, 11:45 | #21 (permalink) | |
my gd90 is alive ;-) But when i want to change the imei, to unlock, i get the words: can't find program, or don't exist or something. I want to use gd90_7 but i can't use it? What must i do to unlock? Pascal. | |
11-27-2000, 12:43 | #22 (permalink) |
Junior Member Join Date: Jul 2000 Location: Vienna
Member: 1684 Status: Offline Thanks Meter: 0 | dear pascal i am very pleased to hear that youcan power on your GD90 GD90 mine is still dead, i have given it up, nothing could help mine, i woould like to thank all the friends who tried to help, my thanks go especially to Crew who helped me a lot now, the progs you are trying to use are DOS progs i do naot think that you can start them from Window, you have to start yourcomputer in DOS Mode and then you can use them, that's the way i do it, may be the other friends have a better way Could you just tell me what you did that yours came back to life, you can send me an email if you like i would be very greatfull thanks |
11-27-2000, 21:10 | #24 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | hi everyone my phone is working again, the problem was, i was flashing it with GAD90b12.dat instead of Gad90b12, Nightxyz told me that right at the beginning but i diden't get it, the phone has charging problems but i can repair it, its no big problem thanks to you all Meam |
11-27-2000, 23:15 | #25 (permalink) | |
Can not calculate full checksum ??? What did i do wrong? And how can i see the difference between b12 and b12.DAT ??? When i use after option 1 the 4th option to flash i always get this. I type : c:\flash90\gad90b12 Must i type something else ? Please help Pascal. | |
11-28-2000, 00:02 | #26 (permalink) | |
I selected the wrong file, *.DAT i know that i must use gad90b12 without ext. But how can i select the good one ? Hope to hear from you soon. Pascal. | |
11-28-2000, 00:23 | #27 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | hi pascal what i did, i had a pack flash90 with both GAD90b12.dat and GAD90b12.LZH, i deleted the file gad90b12.dat and then after choosing mnu 4 i just wrote C:\flash90\gad90b12 without extention and flashed the phone, then i got the message can not check-sum indication i pressed esc and went back to the main menu i chose point 6 verify check sum by M.I or something like that, the green light went off and i could then power on the phone and then used the other two progs it worked with my phone hopefully works with yours as wll good luck Meam |
11-28-2000, 02:32 | #28 (permalink) | |
THANK YOU, my GD90 is alive :-) Pascal. | |
11-28-2000, 05:26 | #29 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | Hi to ALL! i am happy for your success and recover your Dead phones.If you need any other flashes then you can visit that site : www.multicentro.com/movilhome/flash.htm Also .dat files are too short long and it uses main big flash file. Best Regards... |
11-29-2000, 07:35 | #30 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | hi my phone is working but the charging is here, the phone charges all the time and the red light is on, i used GD90repair , it said Repair successfully done but it is still the same, i also used GD90unlocker by oldman but the problem is still here, the phone dosen't stop charging anybody has a working solution for this problem best regards Meam |
is there any free way to convert red52 C510 to brown? | ilbefun | Sony Ericsson | 6 | 12-22-2009 08:15 |
Is there an easy way to unlock nokia e71 | donovan2123 | Nokia Base Band 5 ( BB-5 ) | 5 | 06-18-2009 00:37 |
is there a new way to repair eeprom on w370 after flashing | maxheadquarters | Motorola Hardware Repair | 0 | 06-28-2007 06:58 |
is there a special way to boot kg800? | .:GSM International:. | VygisToolbox | 5 | 08-09-2006 12:27 |
