Panasonic Panasonic-News... |
10-19-2002, 23:02 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: BiH, Srebrenik Age: 53
Member: 10960 Status: Offline Thanks Meter: 5 | Total death GD90, help please! Then remove battery and phone is total death. Any solution please? |
10-20-2002, 01:02 | #2 (permalink) |
No Life Poster Join Date: Jan 2001 Location: La Coruņa-Spain
Member: 3035 Status: Offline Thanks Meter: 2 | The only free solution and easiest to do is throw to recycle bin and forget about it. You should read more before play with dangerous phones in flash mode. NEVER REMOVE BATTERIES FROM PANASONIC PHONES UNTILL FLASH PROCESS FINISHES OK AND LED GOES OFF BY ITSELF. Now this serves as lesson to you, next one will not die in your hands if you're a bit smart. And the hard way and maybe expensive if you don't own already the needed hardware is desolder flash ic from phone and reprogram externally by LABTOOL or similar Flash Programmer and solder back to phone. Someone say that using cable with two connectors in paralell can flash the dead phone too, but i think is science-fiction. I hate to give bad news to newbies. |
10-20-2002, 23:57 | #3 (permalink) |
Member: 10960 Status: Offline Thanks Meter: 5 | @Trier Thanks for particular explanation Trier! But, you must know several things about phones. Only Sagem phones going to trash, for now. "Dangerous phones" is not exist and I think is novice-fiction. I'm not "play" with phones and I know this: "NEVER REMOVE BATTERIES FROM PANASONIC PHONES UNTILL FLASH PROCESS FINISHES OK AND LED GOES OFF BY ITSELF" but I not have all day for this phone and remove battery advisedly. Maybe I'm not smart but know what doing. Solution with LABTOOL is not hard and not expensive because I have LABTOOL 48 long time and alive many phones with him but not have adapter for this flash-ram combination. I will repair this phone and explain to other. Sorry for my bad english. P.S. Trier, maybe you are expert or professor, but "bad news to newbies" set back home, maybe you need. Best regards. |
10-21-2002, 08:43 | #4 (permalink) |
Member: 3035 Status: Offline Thanks Meter: 2 | Your reply sounds a bit angry, can't see why. Ok, that's exactly what i said.... But i think as usual here newbies read messages and understand what only g0d knows when the written is not what they want to read, maybe is cause of untrained english, but 90% of the ppl here have his english very untrained (me included). I suggest all to reread the threads and ensure the post is completely understood before reply being angry without cause. Solution will be expensive if you already don't own externall flash prommer so for you will be cheaper cause you have labtool. Anyway if you signed in april 2002 you're still newbie here, sorry if you don't like how it sounds. You're member near 11k so .... Dangerous phones in flash mode exist mate, i will not discuss that, is only novice(if you prefer this word instead of newbie) who don't believe and **** that phones. specially panasonic handsets I really hope you find easy way to repair the dead GD90. I just told you in few lines all what you could have found using search button (what you should have done before post) and read many boring posts about this particular theme. And finally, i'm not any kind of expert and/or professor, but don't worry, next time you will have answers from other "more experienced" members of the forum There's lastly plenty of such members here, hehehehe specially in the group of the last 11000 that signed in the forum. Good luck with your phone, you are going to need it. |
10-22-2002, 00:39 | #5 (permalink) |
Member: 10960 Status: Offline Thanks Meter: 5 | I'm sorry for my angry sound. But this forum not need answers as: "throw to recycle bin" or "lesson to you" or "bad news to newbies" etc. This is not many wise. Ok, I'm new on this forum but this is not cause for shaft. I'm here form April 2002, but active ocupy with electronic from 1987. Of course I'm "member near 11k" because I not have many time for forums, Trier is near 3k and give answers aforesaid, so.. what this mean? And finally, thanks for your regards Trier and I hope to find easy way to repair this phone. Best regards. |
12-01-2002, 00:00 | #7 (permalink) |
Member: 10960 Status: Offline Thanks Meter: 5 | Hi, sorry for my late. Phone is repaired successfuly. Totaly death GD90 can be repaired with "GD90DownloaderV1.0cByIshida". Flash phone with this downloader, then write imei with ghost and set E2P trimmings to default with andromeda 301. Pone is live again! I tested it many time. Best regards. |
12-03-2002, 00:42 | #9 (permalink) |
Member: 10960 Status: Offline Thanks Meter: 5 | May be. But, Your opinion: "The only free solution and easiest to do is throw to recycle bin and forget about it. You should read more before play with dangerous phones in flash mode. NEVER REMOVE BATTERIES FROM PANASONIC PHONES UNTILL FLASH PROCESS FINISHES OK AND LED GOES OFF BY ITSELF" is not good for GD90, because I'm REMOVE BATTERY in any situations and phone goes death (no power up, no ignition, no connect with any software). Then with GD90DownloaderV1.0cByIshida you can set phone to bootstrap mode and flash it, but you can't see light or anything on display, only wait for 100% flash process. I'm try this solution with another GD90 phone and it work successful. If anybody need, I can explain this solution step by step. Best regards. |
12-04-2002, 00:03 | #11 (permalink) | |
Member: 3035 Status: Offline Thanks Meter: 2 | Quote:
So you start Ishida flasher and can put dead phone in flash mode? What if it's B version? Ishida flasher can't put that phones in flash mode even for a 100% working phone only put in flash mode directly A versions. Chapeau for you if your cable and ishida flasher can revive any sw damaged GD90. | |
08-22-2003, 17:10 | #12 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | hy i am having problem with gd 90 too i tyed to unlock with free ghost soft..same that make gd 30 and 90. After trying too unlock,at the end ,it tels me wrong checksum...But the phone steel conect with program.. So i tried too restore from backup...it say same stuff wrong checksum... Can you post link for GD90DownloaderV1.0cByIshida pls or can you upload somewhere.... |
08-23-2003, 16:16 | #14 (permalink) |
No Life Poster Join Date: Mar 2003 Location: england Age: 65
Member: 24552 Status: Offline Thanks Meter: 13 | i am a bit confused here . You ask for help for a phone you apparantley no how to repair yourself. And Trier was more then helpfull to you . Myself i have never had a nice reply from him . He went out of his way here with good explanation . normaly if you remove battery phone is ****ed 100% you are lucky |
08-23-2003, 19:37 | #15 (permalink) |
Member: 3035 Status: Offline Thanks Meter: 2 | hehehe maybe that day i had good sex Look at the posting date, hehehe it's very old thread. Anyway never is late to receive a nice reply from me Have a nice day RastaMan P.D: @Mtony you probably can't say properly about my real way cause because of beggers, one day, i deleted more than 500 posts (posted dropping here knowledge and help). Obviously you arrived here after the deletion. I'm not bad man, just a bit f4cked with all the freebeggers. My real post counter in this forum should be 1500+ posts, after the deletion in that day i end up with near 40 posts i couldn't delete (closed threads, etc etc). Now i have again 1000 posts and not all are bad manners, but i admit many of them are with angry feelings. Keep trying, i'm not angry everyday. Last edited by Trier; 08-23-2003 at 19:45. |
N95 total death | gacek | MT-BOX | 22 | 09-28-2007 03:09 |
total death sl42 | jaksas | x1x to x45/x50 | 7 | 03-27-2004 16:10 |
siemens m30 total death | DarkSkir | x1x to x45/x50 | 2 | 07-21-2003 10:00 |
Solution for GD90 total death | bello | Panasonic | 16 | 06-02-2003 11:10 |
M35i,total death to moderators | Sandy | x1x to x45/x50 | 6 | 05-14-2001 19:30 |
