Panasonic Panasonic-News... |
10-05-2000, 14:57 | #1 (permalink) |
Junior Member Join Date: Aug 2000
Member: 1930 Status: Offline Thanks Meter: 0 | Save GD50 After I try to unlock with GD50-GD30 repair/unlock tool by Viknet. my phone dead. I can not put it on again. Who has the solution ? |
10-19-2000, 19:43 | #2 (permalink) |
Major Poster Join Date: Oct 2000 Location: Slovenia
Member: 2326 Status: Offline Thanks Meter: 0 | Hello!!! I have same problem but i was fix it with Viknet again. Charge baterry and try agian. You must try many times. If your phone goes in test mode than is ok . Here are instructions:.RUN program "GD50 repair&unlock by viknet v1.0 " (program attached..) 2.press "set test mode" and ON phone..phone goes test mode.. you will see IMEI and SERIAL..you can enter any ... for example IMEI : 555555555555555 SERIAL:IIIIIIIIIIIIII 3. press "Repair and Unlock" you will see again warning message.. repeat this steps Until you see IMEI: FFFFFFFFFFFFFF0 SERIAL:yyyyyyyyyyyy that is very important.. at this point you will enter IMEI : 449121882548521 SERIAL : 125005687236501 ( not magic numbers just fit) and press "Repair and Unlock" phoen lights will up..and nothing on the screen.. press keys..and lights still ON.. keep about 2-3 minutes of this position.. (keep pressing keypad,linghts ON and nothing on the screen..) 4. after 2-3 minutes OFF the phone and ON again..THAT'S ALL.. ------------------ Best Regards Greetings from Slovenia [email protected] |
Save Energy to Stop Global Warming and to Save our EARTH !!! | SinghForHelp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-19-2010 18:46 |
6280 chargshow ok but not save charg save batry | ahmedbarra | Nokia Hardware & Hardware Repair | 6 | 02-14-2010 19:06 |
Saved or not Saved number . | dynamic-gsm | GSM Programming & Reverse Engineering | 0 | 08-23-2007 12:14 |
gd50 chbxs | ARt | Panasonic | 0 | 03-22-2000 11:27 |
dead gd50 | ARt | Panasonic | 0 | 03-13-2000 10:38 |
