Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 04-06-2006, 08:51   #1 (permalink)
Member: 225180
Thanks Meter: 2
Thumbs up Unlock Flash Gu87 Gd87 Gd88 Step By Step
it might seem a bit hard to do, but once you finish the first step ( flash the phone ) the rest is easy
PS: DO NOT INTERRUPT THE FLASH UNTIL IT'S A %100 DONE
before unlocking your phone you need to downgrade the software version by flashing it with A22
1. A Panasonic GU87 Handset FULLY CHARGED
2. A Serial (not usb) Data Cable.
3. WinMoDo Software :http://unlockeasy.com/modules.php?n...=titleA&show=10
4. Flash Files :http://unlockeasy.com/modules.php?n...download&cid=53
5. CB2000 :http://unlockeasy.com/modules.php?n...wdownload&cid=8
6. CRACK2D (panasonicgd 6x and gd8x) http://unlockeasy.com/modules.php?n...=titleA&show=10
7. driver for the phone (Data Connection Assistant Version 4.0) http://www.panasonic.com/consumer_e...t_downloads.asp
after you download the listed above, install the driver for the phone then
run WinMoDo
Lets get started;
1. Select Com port.
2. Select phone model ( In this case choose "GD87" )
3. Select baud rate, choose "115200"
4. Make sure the 2 boxes (MAIN AND BOOT) are green by pressing them. ( when the boxs are green this defines that the part of the phone will be flashed, when red it will not be flashed)
5. Connect phone to the cable ( Phone must be off )
7. Now choose image file ( The image file is the main filmware of the phone, this does not contain language packs).
8. When the above is completed simply press the " Start download button".
9. When the progress report window shows "signalling" press the power button on the phone for a second (do not power on the phone)
10. Now just wait approximately 15 minutes, within in 15 minutes you will see various reports in the progress report window, as below.
As the phone is being flashed you will see the vertical progress bar moving towards 100% , as below
11. If every thing went according to plan the last progress report window will display " Download completed successfully"
12. now places 2 pieces of Scotch tape of the size of a copper contact on pines 4 and 10 of the GD87. Check that the insulator does not overflow on another pine
13. start CB2000.
Click on Handset Power and lights the GD87 immediately.
Go in Data and Write Setting Function Clear (Memory Erase).
close the interface, disconnect the cable.
replug the GD87, and start Spunlock (Crack2).
In the mitre configuration, select the good port COM, that which you connected on the PC.
Click on Read GD87/88 codes.
Eeprom is freed automatically, but the manipulation will be done since the mobile:
Light the GD87 without sim, slaps 746 then the central key 2 times
Enter the Net codes with 16 digits.
readoybdmobile
The Following User Says Thank You to readoybdmobile For This Useful Post:
Old 04-06-2006, 17:21   #2 (permalink)
Registered User
Member: 20027
Thanks Meter: 5
Wow... detail info, but 3-4 years old...
The Following User Says Thank You to prasse For This Useful Post:
Old 04-07-2006, 17:54   #3 (permalink)
cyberbob's Avatar
Member: 19426
please help unlocking my gd87...I have rs232 cable only...
The Following User Says Thank You to cyberbob For This Useful Post:
Old 05-28-2006, 23:32   #4 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
is really tough .take a year of process
The Following User Says Thank You to damabib For This Useful Post:
Old 05-29-2006, 00:39   #5 (permalink)
DeDo Gsm1911's Avatar
Member: 56038
Thanks Meter: 171
it's very new post if you post it from 4 years ago
lol
The Following User Says Thank You to DeDo Gsm1911 For This Useful Post:
Old 05-29-2006, 12:19   #6 (permalink)
GSM Solutions Ireland's Avatar
Member: 16771
Thanks Meter: 153
The above info is taken from a site i did about 3 -4 years ago.
readoybdmobile -> please be kind enough to give credit were its due! and not claim as your own!
The orignal with full guide and images can be found here
http://www.freewebs.com/flashpanasonic/
Alan Donohoe
Gsm Solutions Ltd
www.GsmSolutionsLtd.com
The Following User Says Thank You to GSM Solutions Ireland For This Useful Post:
Old 06-26-2006, 06:17   #7 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Alan Donohoe
Gsm Solutions Ltd
Just this Solution work for me.
i did not need CB2000
after Flashing Boot and Image code was Successfully Readed by Spunlock 2
thanks all m8s
The Following User Says Thank You to Afzaal For This Useful Post:
Old 06-26-2006, 09:55   #8 (permalink)
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
Thanks Meter: 635
hmmmmmmmm if u check it before posting then it was good idea to post it but i think its good idea also cos alot people having problem to unlock this phone and worry how to flash phone if phone stop flashing in mid or etc... dont worry flash again but dont now put out the battary.....
REGARDS
GSM MIND
The Following User Says Thank You to GSM MIND For This Useful Post:
Old 06-26-2006, 10:26   #9 (permalink)
Member: 196467
Thanks Meter: 13
hi all,
I know its off topic,
Pls can any1 post solution for GD67 ?
I need the flash files infact to downgrade
The Following User Says Thank You to PIMP123 For This Useful Post:
Old 06-26-2006, 10:35   #10 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
[quote=GSM MIND]hmmmmmmmm if u check it before posting then it was good idea to post it
Can u Xplain what do u mean by this????????????
Old 06-26-2006, 11:41   #11 (permalink)
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
Thanks Meter: 635
[quote=Afzaal]
YES SIR i mean brother befor posting u must search it cos this solution is old too old 3 years or might be 4 years and posted by many times with many other fourm users with different subject if u mind then sorry now u happy
REGARDS
GSM MIND
Old 06-26-2006, 14:00   #12 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
What Do u mean by Search b4 Posting
i Searched before Unlocking GD87 So i access this thread.
and why should i Search more when 1st thread's 1st Solution workout for me.
why i care if its old or New Solution and i was not in this field 3 or 4 yrs back.
I Just Know that this is working Solution and what is your Opinion about old Working Solutions if any Solution get older shud we throw those Working Solution in the BIN and Should Search for New Solutions.
i did not Mind at all But its really Shocking for me.
that you are telling me that i should Search b4 Posting.
Whats the Point of Searching Something New about JUST UNLOCKING GD87.
will i be able to active 3G in GD87 if i Search the latest method of UNLOCKING GD87.
I Don't think SO.
anyways My Dear Brother think b4 Posting.
Regards and thx to all m8s.
REGARDS
GSM MIND[/quote]
Old 06-26-2006, 14:07   #13 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
The link is not working any tested flashfiles link have any1
The Following User Says Thank You to ~mr_Ten$ion~ For This Useful Post:
Old 06-28-2006, 20:27   #14 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Thanx i will unlock My 1st GD87 ... tht gr8... thanx
Old 07-20-2006, 11:34   #15 (permalink)
Member: 280901
Thanks Meter: 2
is there any way to change language on front end m8?
The Following User Says Thank You to WalkAndTalkGSM For This Useful Post:
Guide: How to Activate SETOOL Step by Step shahzaadbutt SETool2 66 06-15-2023 11:12
Step by Step unlocking and flashing K608i Red CID49 foony Cruiser Suite 19 04-08-2007 03:51
FREE Unlock MPX200 and 220 Flash parch, step by step menintest Motorola ODM 8 07-21-2005 09:17
Panasonic GU87/GD87/GD88 Unlock EEPROM + A39 Big5 Chiang Panasonic 7 11-05-2003 15:55
Panasonic GU87/GD87/GD88 Unlock EEPROM Chiang Panasonic 3 07-02-2003 01:17
Page generated in 0.23984 seconds with 9 queries
