Panasonic Panasonic-News... |
12-05-2006, 20:58 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Phitsanuloke, Thailand Age: 46
Member: 201888 Status: Offline Thanks Meter: 62 | Unlock X700 problem Today, I have problem about unlock x700. ------------------------------------------------------------------------ Testing COM1 at 115200... Device: X700,X701 Checking data, wait... Action: TestMode On Boot... Press Power button now ! Checking... Boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... FLASH ID: 0089:8862 Connecting Done Check free space... Flash chip supported In progress [eeprom-02]... file saved: Backup_eeprom-02_2006-12-6_1-45-47.30E.bin Loading data... Data loaded Check free space Done Write... Verify result: 0116 Erasing: Eeprom Writing: Eeprom Verifying... Verify result: 01AD Done Write Done Finished Remove/Install battery now ! Time used: 20 sec ------------------------------------------------------------------------ When power ON it, display show Panasonic TAM USB InitialState : 0 When I connect my X700 to PC by usb cable. The PC don't answer. You can see my usb pinout. X700 usb pinout.jpg Why I cann't connect ? Help me Plz. |
12-06-2006, 03:00 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Djazair
Member: 111121 Status: Offline Sonork: 100.99340 : CrKdz13 Thanks Meter: 487 | I - u must post this in the infinity section , not here II -1. Connect ordinary X70 cable (COM port cable) to phone 2. Start software and select COM port, 115200 baud 3. Make "Backup for unlock" option checked 4. Go to "Service" tab and press "TestMode On" button 5. Press phone power button 6. Wait until process complete. result will be like on picture: X700_step-1-complete.jpg 7. Remove/Install battery, disconnect X70 cable. 8. Power-On phone. You will see on LCD info like on picture X700_LCD-1.jpg 9. Connect X700 USB cable. PC ask for drivers. 10. Install drivers from "Drivers" folder 11. You will see on LCD info like on picture X700_LCD-2.jpg 12. Go to "Device Manager" and find "X700 modem" device: X700_Modem_in_Device_Manager.jpg 13. Check, what COM-port used for this "X700 modem": X700_Modem_Properties.jpg 14. Go back to software "Settings" tab 15. Press "Scan" button 16. Select COM port according to "X700 modem" device: X700_Modem_COM-port_selection.jpg 17. Go to "Service" tab and press "Unlock" button It can be that phone LCD blink several times and PC show error during COM port access. In this case press "Stop" button, wait several seconds and press "Unlock" button again. 18. Wait until process complete. 19. Power-On phone and check it. **** and to solve your problem : **** 1. Connect phone to X70 cable (COM port cable) 2. Select ordinary COM-port 3. Power-Off phone 4. Press "TestMode Off" button and press phone power button III- try to read manual |
12-06-2006, 09:08 | #3 (permalink) | |
Member: 201888 Status: Offline Thanks Meter: 62 | Quote:
But, when I goto step 9 the PC don't ask for driver. | |
Unlock X700 problem | anil2006 | Infinity-Box | 1 | 03-07-2008 20:38 |
x700 problem | ruvanw1979 | Infinity-Box | 3 | 09-07-2007 05:59 |
x700 problem | Velko | Infinity-Box | 0 | 11-15-2006 08:25 |
Panasonic X700 Problem | Nasmi | Infinity-Box | 1 | 09-28-2006 17:00 |
x700 problem | monther | Trident/AGERE Platform | 3 | 07-10-2006 06:21 |
