Panasonic Panasonic-News... |
09-16-2004, 19:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2003
Member: 20069 Status: Offline Thanks Meter: 131 | x70...Cb2000 Ver.1.5 ... Need Help ? Last night i got keypad lock on x70 so i just download Cb2000 Ver.1.5 after installing the soft i open it n connect the mob with cable then i click the Handset Power option n i also poweron the mob the soft reads the info . as i had no previous experience of it ,so i just click on "Read Handset" option the new windows open here i saw some more info of the mob where i saw the code field ...But at this point i did the stupid thing the mob which was i think in the Test Mode i disconnected it in hurry . but when i tried to poweron the mob it was not turning on so some 1 plz help me a.s.a.p , how to solve this problem n how i can get it back to normal ... Big thanx in adv the_frightener |
09-16-2004, 19:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Oh May be Boot is lost If Boot is lost then Your Set is Gone You have to desolder the Flash Chip & program it by external programmer OR you can try by Flashing it Use X70 Winmodo Downloader. Flash all including Boot If it takes reads & if flashing start then your Set will be OK use Full Charge Battery |
AdvancedBox 5 need help | JFN | Nokia Base Band 5 ( BB-5 ) | 0 | 04-24-2009 09:12 |
CITROEN gr 2014 error 5 need help with dump | ARAB GSM | CAR Electronics | 1 | 10-20-2007 08:49 |
Need CB2000 ver 1.349 | Alex_BZ | Panasonic | 5 | 07-10-2006 18:03 |
Need link for CB2000 ver. 1.343 | dominik | Panasonic | 1 | 03-17-2003 15:28 |
UNLOCKIN M 30 WITH VER 2.5.0 HELP NEEDED | shailesh | x1x to x45/x50 | 1 | 11-13-2001 16:21 |
