10-07-2008, 23:02 | #46 (permalink) |
No Life Poster Join Date: Apr 2004 Location: EGYPT & oman Age: 39
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | JAF Setup 1.98.60 ready... - added latest ini for BB5 tp unlock - latest language ini file - added support for N96 usb flashing. FBUS mode will be implemented in future versions. However with usb dead mode you can revive dead phones also. - added latest flash loaders to support N96 - other small reported bugs fixed http://www.venus-box.com/venus_updates/JAF/ |
11-25-2008, 22:29 | #47 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | JAF Setup 1.98.61 ready... -reverted to old loaders. Now it's all fbus phones are working again. N96 it's supported for USB only. http://www.venus-box.com/venus_updates/JAF/ |
01-14-2009, 20:30 | #48 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | Release Date: 14/01/2009 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_DCTxBB5 v2.0.8.0a ----------------------- 1. Flash Fix added to installer Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. SAMs V 2.0.8.1 --------------- TRIDENT CC01,P258,U600G added (DUNL,IM,FL) TRIDENT VISION B220,B310,B320,B518,B520,B528,J600G,J610,J618,M318 ,M620,M628 added (CUNL,FL) L320 added (DUNL,IM,FL) (Use [Reset MMI] if phone ask for password) OM(SYSOL) B110 added (DUNL,IM,FL,SECT) SWIFT D618,D980,E2510,F250L,F268,F278,G600G,G618,J770,J8 08E,L258,M150, M200,M3200,M3510,S3600,T429,U708E,U808E added(DUNL,IM,FL,SECT) D780,D788,D880,D888,D980 SLAVE support added (DUNL,IM,SECT) J150 fixed (DUNL,IM,SECT) IM Rebuild added and RAW TFS Read fixed for these models: D618,D780,D788,D880,D888,D900i,D908i,D980,E200,E20 8,E250, E250D,E250V,E256,E258,E258D,E251,E251C,E480,E488,E 590,E598, E740,E747,E830,E838,E2510,F110,F250,F250L,F258,F26 8,F278,G600, G608,G808E,G618,J150,J210,J700,J708,J770,J808E,L25 8,L310,L600, L608,M150,M200,M610,M618,M3200,M3510,P180,P260,S36 00,T429,U708E, U808E,U908E (Need power up phone with battery after IM done !) SWIFT-AEROFONE B130,B130S,B130T added (DUNL,IM,FL,SECT) SWIFT-3G B2700,J800,L700,L708 introduced (DUNL,FL,SECT,BT) SKYWORKS C100 - 'Not Released Yet' bug fixed. QUALCOMM F480G,F480H,M7500,M8800,S7330,U900F,U900G,U900K added(FL,INF,REUL) Added QualComm mode support: (*#QUAUSB# to enter QualComm mode, QC Debug Interface on USB) (*#SAMUSB# to enter Samsung mode, QC Debug Interface on RJ45) QCDI Info, NVM Read, RAM Read added. UNLOCK and UNFREEZE introduced for these models: F480x,L760x,U900x,Z240 (Use [QCDI Info] button to readout keys) COMMON Stop button added. User interface localisation. Update Client V 2.0.8.1 ---------------------- Fixed Exception errors on req-fbi process !!!THERE IS NO NEED TO UPDATE YOUR HWK SINCE 2080 RELEASE IF ITS WORKING OK !!! We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future. Conditions:- 1. Only 1 contributer per language. 2. You must know how to use the software and what each function does. 3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required. http://www.venus-box.com/venus_updates/HWK/ |
10-30-2009, 02:48 | #49 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite. You MUST update your HWK using client 2.0.9.0, old client versions will no longer work. You MUST be running HWK software 2.0.9.0 to access support. UFS_DCTxBB5 v2.0.9.0 ---------------------- 1. New BB5 products: RM-424,RM-465,RM-469,RM-481,RM-482,RM-483, RM-491,RM-504,RM-518,RM-547,RM-555,RM-561,RM-564,RM-566,RM-602 (6720c-1,5730s-1,E52-1,E52-2,E55-1,E55-2,6710s-1,5530c-2,3720c-2, 6730c-1VF,N97-4,2700c-2,6720c-1b,6730c-1,5800d) 2. New DCT4+ products: RM-519,RM-520 (2720a-2,2720a-2b) 3. New Samsung Flash Chip: 00EC2606 (K8S3215ETF) 4. Corrected VPL parsing for some models (N97) 5. Only NU48F256 left in [1331] option and moved to BB5 Tab. 6. SX4 bypass introduced using temporary NPC certificate erase. 7. [One Boot] option introduced (RAPx based One MCU products) 8. Enabled Files Multiselect, when Writing Certificates. 9. Erase Option for BB5 (for Experts Use Only !) Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.9.0 ----------------- 1. Unlock Codes Display for Infineon EGOLD Voice added (Boot and See NCK Code for Instructions Press UNLOCK) SAMs V 2.0.9.0 --------------- TRIDENT T539 added (DUNL,IM,FL) TRIDENT VISION Fixed MSL algorithm for some models (C3050,...) SWIFT D606,D900E,E260,M2310,P220,S366,S5050,S5200 added(DUNL,IM,FL,SECT) SWIFT-AEROFONE B270i,C276,C276L,E1070M,E1070T,E1075,E1075L,E1105T ,E2100B, E2210B added (DUNL,IM,FL) QUALCOMM Manual Port Selection Added (Use Refresh, After Each Phone Reboot or Reconnect) (Untic QualComm Mode, Before Flashing) F480R,i6210,U900W added. UNLOCK and UNFREEZE added for these models: A736,A737,F490,G800,G800L,M7600,S5600,U900W,Z400,Z 540 We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future. Conditions:- 1. Only 1 contributer per language. 2. You must know how to use the software and what each function does. 3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required. |
Advance cdma Team Product Updates LGRDX 1.00.17 | DYNET | Service Products News & Updates | 0 | 03-13-2010 12:37 |
Advance Cdma Team Products Update & Release. | rajiv007 | Service Products News & Updates | 0 | 02-28-2010 14:03 |
New Products Update Same Price | TaHiR | Main Sales Section | 0 | 05-03-2004 11:14 |
