12-25-2009, 13:26 | #17 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 538921 Status: Offline Thanks Meter: 0 | Quote:
12-26-2009, 08:40 | #19 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | My dear brother your box serial number corrupted rebuild it again your problem 1000% solved contact me at [email protected] 0091 9315848386 |
12-27-2009, 13:55 | #20 (permalink) |
Registered User Join Date: Dec 2007 Location: Chandigarh
Member: 655438 Status: Offline Thanks Meter: 146 | I have fixed my problem myself. The is to do just open your HWK and just to refix the card. If its still in same condition put some heat on it. This will fix your problem definately and 100% |
01-09-2010, 07:38 | #26 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | Error In Connecting HWK Error in updates and contact ur reseller Box_auth_Error authenticated I've facing same problems like you with the help of my friend name Andy_lechna, he solve my problem Solution: 1: uninstall UFS suite 2: Uninstall UFS Support Suite 3: use UFS3 tools ( just surf where to Download the UFS3 tool or contact our brother technicians, or contact me on my YM, [email protected]) using UFS3 tools 1: click connect 2: check write firmware and check the write EEPROM 3: FW v2.6(last) 4: check fix and update 4: closed the UFS3Tools 5: install UFS SUpport Suite 6: Update Client and update your firmware ( if contact your reseller occurs, you should wait until 3 days and update it again) 7: update driver for your device 8: connect UFS bb5 9: error in box connection occurs connect it again 10: DONE added: before you install UFS support suite and UFS Suite, please use first the UFS3 TOOLS in order not to wait for 3 days because once you update your box and you use the UFS3 tool, contact your reseller occurs Thanks to Boss andy_lechna Hope this will help of you |
02-08-2010, 06:31 | #28 (permalink) |
Junior Member Join Date: Nov 2007 Location: hyderabad
Member: 622264 Status: Offline Sonork: [email protected] Thanks Meter: 4 | erro login helpme plzzzzzzzzz -- UFSx Device: UFS3 SarasSoft, USB S/N: 95438 -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 95438 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-9FC74A354160002C -- HWK Status : 1, DL: 0 Error connecting UFS:HWK LOGIN ERROR:-4 |
02-08-2010, 13:44 | #29 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
02-08-2010, 13:51 | #30 (permalink) | |
1'st Remove Your Old Version. After You Setup HWK__Supprt_ Suite_v02.09.000 Or Connect Your Device. Next Stpe your Hwk-Update Client After Setup Hwk-suite. I Hope your Problem Is Success. Last edited by ...:::::NP™:::::...; 02-08-2010 at 13:58. | |
