Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 11-28-2009, 05:10   #16 (permalink)
Member: 655438
Thanks Meter: 128
plz help my HWK was working ok last night and now it shows this to me
The Following 2 Users Say Thank You to deep_6111 For This Useful Post:
Old 12-25-2009, 13:26   #17 (permalink)
Member: 538921
Originally Posted by hacell View Post
locating hwk upgrade server...
Hwk upgrade server found!
Preparing connection to server...
Connecting to hwkupgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Server reported error:account for this hwk module does not exist on server. please contact your reseller!
This the problem sir,,because your hwk is bad:d
tŞkkkkkkkkkkkkkkkkkkkkkkkkk
Old 12-25-2009, 15:30   #18 (permalink)
Member: 1116719
Thanks Meter: 542
just update 100% ok
Old 12-26-2009, 08:40   #19 (permalink)
logicmobile's Avatar
Member: 1016569
Thanks Meter: 227
My dear brother
your box serial number corrupted
rebuild it again your problem 1000% solved
contact me at
[email protected]
0091 9315848386
Old 12-27-2009, 13:55   #20 (permalink)
Member: 655438
Thanks Meter: 128
I have fixed my problem myself. The is to do just open your HWK and just to refix the card. If its still in same condition put some heat on it. This will fix your problem definately and 100%
Old 12-29-2009, 04:11   #21 (permalink)
rudifast's Avatar
Member: 1028864
Thanks Meter: 59
Attachment 216057
that's probably from usb power problem sir.
Old 01-06-2010, 10:40   #22 (permalink)
Member: 395514
Thanks Meter: 18
HWK Update error
my hwk not update.every time error a message
Old 01-06-2010, 11:12   #23 (permalink)
Member: 395514
Thanks Meter: 18
HWK Update error
please chk this message and solb it
thank you
Old 01-09-2010, 05:48   #24 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,366
Please you are use of ufs-hwk real chips or latest virson HWK_Suite_Setup_h3rdi_v02.09.000b I hope Your Problems'' is Solvd
Good Luck
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 01-09-2010, 05:50   #25 (permalink)
Moderator
Member: 1162626
Thanks Meter: 9,366
Good Luck
Old 01-09-2010, 07:38   #26 (permalink)
Member: 853601
Thanks Meter: 230
Error In Connecting HWK
Error in updates and contact ur reseller
Box_auth_Error authenticated
I've facing same problems like you
with the help of my friend name Andy_lechna, he solve my problem
Solution:
1: uninstall UFS suite
2: Uninstall UFS Support Suite
3: use UFS3 tools ( just surf where to Download the UFS3 tool or contact our brother technicians, or contact me on my YM, [email protected])
using UFS3 tools
1: click connect
2: check write firmware and check the write EEPROM
3: FW v2.6(last)
4: check fix and update
4: closed the UFS3Tools
5: install UFS SUpport Suite
6: Update Client and update your firmware
( if contact your reseller occurs, you should wait until 3 days and update it again)
7: update driver for your device
8: connect UFS bb5
9: error in box connection occurs connect it again
10: DONE
added:
before you install UFS support suite and UFS Suite, please use first the UFS3 TOOLS in order not to wait for 3 days because once you update your box and you use the UFS3 tool, contact your reseller occurs
Thanks to Boss andy_lechna
Hope this will help of you
Old 01-09-2010, 07:44   #27 (permalink)
Member: 853601
Thanks Meter: 230
Download the UFS3tools
here is the link: http://www.mediafire.com/?jymzxjfegoj
Old 02-08-2010, 06:31   #28 (permalink)
Member: 622264
Thanks Meter: 4
erro login helpme plzzzzzzzzz
-- UFSx Device: UFS3 SarasSoft, USB S/N: 95438
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 95438
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TWISTER
-- HWK ID : A1.04-PRO1-9FC74A354160002C
-- HWK Status : 1, DL: 0
Error connecting UFS:HWK LOGIN ERROR:-4
Old 02-08-2010, 13:44   #29 (permalink)
Moderator
Member: 1162626
Thanks Meter: 9,366
Question
-- UFSx S/N : 95438
-- Licence 5 : True
Please Check Or Change Your Usb Cabel
Old 02-08-2010, 13:51   #30 (permalink)
Moderator
Member: 1162626
Thanks Meter: 9,366
Exclamation
-- UFSx S/N : 95438
-- Licence 5 : True
1'st Remove Your Old Version.
After You Setup HWK__Supprt_ Suite_v02.09.000 Or Connect Your Device.
Next Stpe your Hwk-Update Client After Setup Hwk-suite.
I Hope your Problem Is Success.
Page generated in 0.43552 seconds with 9 queries
