02-09-2010, 08:15 | #31 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | don,t use third party tools it can damage your Hwk chip .. Just try after some time i think its server problem if problem is persist contact me with team viewer at my Id THANKS |
The Following User Says Thank You to logicmobile For This Useful Post: |
02-21-2010, 21:40 | #32 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Sri Lanka
Member: 164422 Status: Offline Thanks Meter: 24 | While running update client i keep getting this error message - Authentication stage error: Access violation at address 00402D5D in module 'UpdateClient.exe'. Read of address 00000014 |
02-22-2010, 05:53 | #34 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
i hope your ufs is Connected | |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
02-23-2010, 16:25 | #36 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1243394 Status: Offline Thanks Meter: 1 | this is the log -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS. -- UFSx Device: UFS-NBOX SarasSoft, USB S/N: xxxxxx -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS ! -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ERROR : 0004 -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ERROR : 0004 and when i start to update here it is Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:2/23/2010 3:22:50 PM ---------- -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS ! -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ERROR : 0004 -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ERROR : 0004 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Access violation at address 00402D5D in module 'UpdateClient.exe'. Read of address 00000014 |
02-26-2010, 12:32 | #39 (permalink) | |
Please Your Hwk Upgrade after 24 Hour Latter I Hope Your Problem Is Solved........... | |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
02-28-2010, 02:57 | #42 (permalink) | |
Member: 1243394 Status: Offline Thanks Meter: 1 | now its work muahahahahahaha Quote:
result.... hwk login error 1 change to hwk login error 5 update result always couldn't be done so i just reinstall my windows with no other appication and freeze it..... with deepfreeze tool and install ufs support suite setup and holla no error dont forget the reg file and global option before installing ufs suite setup and ..... holla it work..... damn.... i hope this can solve problem for people that having hwk error login 1 or hwk error login 5 fyi.... i am using ufs suite setup 208 | |
The Following User Says Thank You to imamikola For This Useful Post: |
