Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 06-17-2011, 18:17   #121 (permalink)
Member: 1599373
Please help me sort out this problem. please please. you can also notify me on facebook. name is joe cow-buoy siafunda
Upgrade log:
---------- HWK Update Client v 2.0.9.0 ----------
---------- HWK upgrade started:6/17/2011 10:16:27 AM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N :
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TWISTER
-- HWK ID :
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Connection to server failed: Socket Error # 10060
Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
The Following User Says Thank You to Cow-Buoy For This Useful Post:
Old 07-06-2011, 00:35   #122 (permalink)
Member: 1482124
Sonork: x
this is my error how do i fix it
-- Reset Failed, Trying to Repair UFS ...
-- Boot Fail: C:\Program Files\Common Files\SarasSoft\Ufs.sdb
-- UFSx Device: UFS3 SarasSoft, USB S/N: 76000
Old 07-06-2011, 00:35   #123 (permalink)
Member: 1482124
Sonork: x
keep getting error 5 message
Old 07-06-2011, 21:50   #124 (permalink)
Member: 375331
Thanks Meter: 17
This is my error, installing hwk!
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:06/07/2011 04:42:26 PM ----------
-- UFSx S/N : 78570
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-CCCC7EF34160007F
Connection to server failed: Socket Error # 10061
Connection refused.(No connection could be made because the target machine actively refused it.)
Old 07-07-2011, 06:41   #125 (permalink)
SAHEB's Avatar
Member: 173509
Sonork: 100.1584320
Thanks Meter: 96
Upgrade log:
-- UFSx S/N : 78570
-- Licence 5 : True
hi,ur problem due to server.try after some time.
The Following User Says Thank You to SAHEB For This Useful Post:
Old 07-09-2011, 05:40   #126 (permalink)
Member: 1482124
Sonork: x
Mubashar cant you plz give me the link to this new usb setup u mentioned plz.
Old 07-09-2011, 22:23   #127 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 773
Arrow hwk update problem
Upgrade log:
-- UFSx S/N :
-- Licence 5 : True
-- HWK ID :
plz disable antivirus and fairwall than update again ,,,
Old 07-10-2011, 13:20   #128 (permalink)
Member: 692288
how about this sir???
Upgrade log:
---------- HWK Update Client v 2.1.0.0 ----------
---------- HWK upgrade started:7/10/2011 7:20:46 AM ----------
-- UFSx S/N : 71139
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-F7555F8641600044
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Old 07-10-2011, 16:02   #129 (permalink)
Member: 367398
hwk error
install not authored you have not updated your hwk on this pc with the latest update client.client compare pls help me
Old 07-11-2011, 04:02   #130 (permalink)
Member: 692288
please help me sir..
how about this..
Upgrade log:
---------- HWK upgrade started:7/10/2011 10:16:14 PM ----------
-- UFSx S/N : 71139
-- Licence 5 : True
Old 07-12-2011, 07:14   #131 (permalink)
Member: 923032
Sonork: 321321
Thanks Meter: 17
Please help me Please help me
Old 07-12-2011, 21:35   #132 (permalink)
amit.alag's Avatar
Member: 373527
Thanks Meter: 68
your system clock is not correct or saras server is currently close plz patience now and try to next 2 days
Old 07-13-2011, 03:43   #133 (permalink)
Member: 1615042
Thanks Meter: 7
I am tested More-time when Show This Message (A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.) Just Try Your Internet Connection........
Old 09-17-2011, 18:06   #134 (permalink)
Member: 407338
Sonork: 100.1608994
Thanks Meter: 5
Dear friends
i have some different problem
1. my HWK installs properly
2. im able to access support
3. i can get INFO of DCT-4 & BB-5
4. Problem is i cant check
always first boot error
my interface is ok & tested
firmware upgrade done
UFS3tool used
any solution
Old 09-17-2011, 18:22   #135 (permalink)
Member: 1591394
Thanks Meter: 552
if all ok then you should check cable
Page generated in 0.23475 seconds with 10 queries
