Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 08-29-2013, 08:55   #46 (permalink)
mubashar757's Avatar
Member: 1702642
Sonork: 100.1638878
Thanks Meter: 85
hwk teem halp me
Old 08-29-2013, 11:00   #47 (permalink)
Member: 2005427
Originally Posted by akhil_bbsr View Post
claen ur pc or format then reinstall again
sir mera ufs3 eer. 38 de reha he .pc formet bhi kar diya fir bhi
Old 08-29-2013, 12:42   #48 (permalink)
aizazahmademail's Avatar
Member: 1858524
Sonork: 100.1651800
Thanks Meter: 78
Brothers!
can not open internet url internet open url failed
It's mean your connection too slow... click on install button again your files will downloading...
Old 08-30-2013, 16:05   #49 (permalink)
Member: 1961467
Thanks Meter: 3
same problem with me i format my pc and antivirus off but same problem dear.?......
Old 08-31-2013, 06:52   #50 (permalink)
Member: 1837174
Thanks Meter: 3
Originally Posted by rajendra orissa View Post
1st install HWK_Support_Suite_Setup_v02.20.000,2nd install UFSx_Support_Suite_Setup_v02.03.00.00 then update box and install software then solve this problem:error please reinstall hwk support suite eny problem call +919583334333
thanks so much , my problem solved with your procedure ....
Old 08-31-2013, 07:47   #51 (permalink)
Member: 1837174
Thanks Meter: 3
Originally Posted by mubashar757 View Post
Team cant help , I had the same problem , may be you are using 2 g internet , use broadband or 3 g -- problem will bw solved . OR , continue with the faild try and try and complete total download , check box - re install HWK_Support_Suite_Setup_v02.20.000 then install UFSx_Support_Suite_Setup_v02.03.00.00 , check - update box , check box - check server - 3 or 4 file will be downloaded - check box again - remove box , restart computer , all will be okay
Old 08-31-2013, 09:59   #52 (permalink)
amurale72's Avatar
Member: 1849338
Sonork: 100.1646373
Thanks Meter: 93
FIRST UNINSTALL OLD SET UP AND DRIVERS
RESTART
DISABLE ANTI VIRUS AND FIREWALL
INSTALL FIRST DRIVERS UFS_USB_Driver_30830.zip
GO DIRECT INSTALL UFS_PANEL_2302.zip or https://hotfile.com/dl/240783993/581..._2302.zip.html
SCAN BOX
CHECK BOX
UPDATE BOX AND AUTH SUCCESSFULLY
CHECK SERVER
INSTALL 1070 FILES
DO UPDATE WITH HIGH SPEED INTERNET 3G OR BRAODBAND EARLY IN THE MORNING BEFORE 6* CLOCK BECAUSE NETWORK TRAFFIC LOW IN SERVER THANK U
Old 08-31-2013, 10:01   #53 (permalink)
amurale72's Avatar
Member: 1849338
Sonork: 100.1646373
Thanks Meter: 93
I am using windows 8 pro it works fine ufst 2.3.0.2
Old 08-31-2013, 14:36   #54 (permalink)
Member: 1714579
Sonork: 601335
Thanks Meter: 11
error
Please Reinstall HWK Support Suite
plz give solution odia sir
Old 08-31-2013, 16:43   #55 (permalink)
binaybiswas's Avatar
Member: 1093574
Sonork: 100.1646163
Thanks Meter: 473
Arrow HWK Error Please Reinstall HWK Support Suite Solution.
Uninstall old Version then -
Open "Run" program have in Yr computer. Then Type- "regedit" & press ok - goto "Local Machine" - Go to "Software" - Delete "Sarasoft" OR" click "Sarasoft" & Delete In "HWK Support Suite".
Then Install New Version. It will 100% work.
The Following 3 Users Say Thank You to binaybiswas For This Useful Post:
Old 09-04-2013, 09:46   #56 (permalink)
Member: 1467720
plese solve my problem
Old 09-04-2013, 10:24   #57 (permalink)
Member: 1858524
Sonork: 100.1651800
Thanks Meter: 78
Bro contact me on facebook i will help you
userneme: aizazahmademail
Old 09-06-2013, 20:46   #58 (permalink)
Member: 1052068
Sonork: rakeshpriy
Unhappy
Originally Posted by ..::Rana Bilal::.. View Post
contect with me on sonork.i face that problam then i clear it
same problem brother help me remote support
Old 09-08-2013, 08:38   #59 (permalink)
Member: 1819296
reintal hwk saport suite
Old 09-09-2013, 09:59   #60 (permalink)
Member: 1860032
Error
Page generated in 0.37941 seconds with 8 queries
