Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 09-25-2014, 05:38   #31 (permalink)
Member: 1191119
Fatal LOGIN Error, Need Repair Box, Contact Distributor virsion 2.3.6 but problem not solve sir plz halp me
Old 11-05-2014, 08:10   #32 (permalink)
Member: 2279761
Last Server Update: 2014/08/22
Active Panel Version: 2.3.0.6
Box: 1 Location: 8481 Serial: 56643
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 56643
LIC: True
Your IP: 197.250.129.213
Support: Bad HID, Cannot Access Support
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 56643
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 56643
LIC5: True
BOXK: 2
LIC: True
failed in 12 and error 102 sevver support error and ihave already use HWK RASKULATOR butbsame problem first
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7
UFS_USB V2.6 (c) SarasSoft 2005., Sn: 56643
BOX: CORRUPTED or MANIPULATED
REST: Ok
NVML: Ok
INIT FBI Failed: 1
then if i try again error 102 be back help me plz
Old 11-08-2014, 13:10   #33 (permalink)
Member: 1356973
Sonork: govind99501
Red face
box gives error 102
Old 11-24-2014, 18:50   #34 (permalink)
Zegarek's Avatar
Member: 551345
Sonork: 100.1590161
Thanks Meter: 319
Press "Update Box" AGAIN
Old 01-18-2015, 13:57   #35 (permalink)
Member: 477842
Thanks Meter: 80
Originally Posted by O J E B View Post
App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft
Box: 1 Location: 21553 Serial: 46827
Boot Id: 62 CF
Box Login Failed
Bad IX: ABCD
Failed: -102
HID Number Corrupted, Try to Use [Update Box]
Boot Id: 62 CF
Box Login Failed
help me brother......???
Bro , try to upgrade your box hwk firmware 2.6 to 2.7
Naprawa UFS Box HWK - ufs saras HWK - AT-KOM - Chomikuj.pl
Ufs 2.6 to 2.7.exe
then use , UFS Panel to check box , update , many times (hardware )
then go to Software and tick Check server then select all and install
and your hwk will be works fine
If I help then click - THANKS Button
Old 01-18-2015, 21:54   #36 (permalink)
bighiner's Avatar
Member: 679176
Sonork: 1585224
Thanks Meter: 119
i think is u speed internet conection to slow
Old 01-20-2015, 04:37   #37 (permalink)
Member: 1927293
Thanks Meter: 2
big thanks mine is ok now!!! i used raskulator!!! thanks!!!
Old 01-20-2015, 17:43   #38 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 426
who release this version UFS_PANEL
Old 02-06-2015, 17:11   #39 (permalink)
Member: 1829410
Thanks Meter: 4
Box: 1 Location: 82 Serial: 93206
Boot Id: 62 CF
Box Login Failed
Old 03-19-2015, 21:36   #40 (permalink)
Member: 1434277
Fatal LOGIN Error, Need Repair Box, Contact Distributor pleez hep me
Old 04-17-2015, 08:31   #41 (permalink)
Member: 2371961
i have also same problem ,please solve this problem.
Old 04-19-2015, 05:50   #42 (permalink)
Member: 2279761
for me iread ol post but ther is no solution but ijust open it inside the box and isee that chip is not in its place....try this and sory for my bad english
Old 04-20-2015, 10:39   #43 (permalink)
Member: 721956
Thanks Meter: 6
Old 04-20-2015, 10:42   #44 (permalink)
Member: 721956
Thanks Meter: 6
Thumbs up Follow this link
Old 08-02-2015, 17:49   #45 (permalink)
Member: 2379260
Thanks Meter: 8
i have same problem .
The Following User Says Thank You to said bashri For This Useful Post:
Page generated in 0.23892 seconds with 8 queries
