Help me.HWK upgrade fatal login error App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 21553 Serial: 46827 Boot Id: 62 CF Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 21553 Serial: 46827 Boot Id: 62 CF Box Login Failed Fatal LOGIN Error, Need Repair Box, Contact Distributor help me brother......??? |
same with me plz share tool to repair ............... |
::::::::::::::: I think, U are using micro hwk OR" Old hwk. Micro hwk not supporting new version. Contact Yr reseller for Upgrage Yr box. OR" Download Update Client for micro Hwk: updateclient(gb-93206) - Download - 4shared - parvez_makmobile OR" Search in google this tool "UpdateClient(33133)" or" "UpdateClient(GB-93206)" |
I have the same problem, how to solve ??? |
internet connection must be fast bro |
App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 273 Serial: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 95867 HID: 82C0C845002700B1, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 9990 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 |
Box: 1 Location: 17 Serial: 74543 Boot Id: 62 CF Box Login Failed Fatal LOGIN Error, Need Repair Box, Contact Distributor |
contact me on yahoo or sonork |
download and use ufs pannel, your problem will solve:cool: |
u have losnn hwk box |
hwk error 102 solution hi all, if ur box gives error 102 & fatal ligin error try HWK RASKULATOR ur problem 1000% solved. Thanks |
Last Server Update: 2013/11/05 Active Panel Version: 2.3.0.3 None of Boxes Selected or Active Use [Check Box] in Hardware Page App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft Box: 1 Location: 801 Serial: 78102 Box Boot Failed Bad IX: ABCD Failed: -101 HID Number Corrupted, Try to Use [Update Box] App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft Box: 1 Location: 801 Serial: 78102 Box Boot Failed Bad IX: ABCD Failed: -101 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 801 Serial: 78102 Box Boot Failed Fatal BOOT Error, Need Repair Box, Contact Distributor None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft None of Boxes Selected App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft Box: 1 Location: 801 Serial: 78102 Box Boot Failed Bad IX: ABCD Failed: -101 HID Number Corrupted, Try to Use [Update Box] None of Boxes Selected or Active Use [Check Box] in Hardware Page Box: 1 Location: 1041 Serial: 78102 Box Boot Failed Fatal BOOT Error, Need Repair Box, Contact Distributor somebody HELP me !!!!! |
All For thats Problem i happen to me to.... and the solution is : Quote:
you can search and Download at 4shared How to Use it ? Open the Palication,Click "Connect" and you'll see your Box ID Serial. Don't Change the serial,just Click "Write Razkalizement" until the Process finish(will finish in 5-10 second). close the Aplication,and your box & Hwk ready to Upgrade again... i hope this can help U all... |
