04-25-2011, 13:36 | #17 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Server is working fine. Log report . Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:4/25/2011 2:15:34 PM ---------- -- Target Id : xxxxxxxx -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : vxvvvvvvvvvv -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-xxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:2:15:50 PM ---------- |
04-26-2011, 12:38 | #18 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1502539 Status: Offline Thanks Meter: 41 | hwk upgred setup site 1st Setup:HWK_Support_Suite_Setup_v02.10.000 (Note): HWK_Support_Suite_Setup_v02.10.000 then start HWK upgrade to finish. then setup step by step below under check. 2nd Setup: HWK_Suite_Setup_v02.10.000 3rd setup: HWK_Suite_Minor_v02.10.001 4th setup: HWK_Suite_Minor_v02.10.002 5th setup: HWK_Suite_Minor_v02.10.003 6th setup: HWK_Suite_Minor_v02.10.004 |
The Following User Says Thank You to memonarif For This Useful Post: |
05-19-2011, 01:40 | #19 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 586472 Status: Offline Thanks Meter: 6 | sir need help my hwk error -- UFSx Device: UFS3 SarasSoft, USB S/N: 38442 -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 38442 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK NOT CONNECTED or DEAD -- HWK ERROR : 0010 |
The Following User Says Thank You to jhonrie For This Useful Post: |
05-26-2011, 17:49 | #20 (permalink) |
Freak Poster Join Date: May 2011 Location: INDIA
Member: 1584831 Status: Offline Thanks Meter: 46 | hwk update failed i have also same problem , unable to update.if any one have perfect solution share with us...... |
The Following User Says Thank You to ashish.srk2 For This Useful Post: |
05-26-2011, 18:10 | #21 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Nepal Biratnagar Age: 39
Member: 646340 Status: Offline Thanks Meter: 15 | (Note): HWK_Support_Suite_Setup_v02.10.000 then start HWK upgrade to finish. then setup step by step below under check. 2nd Setup: HWK_Suite_Setup_v02.10.000 Mr-jhonrie you nead repair hwk your hwk is damag |
05-27-2011, 05:37 | #22 (permalink) | |
Junior Member Join Date: Apr 2011 Location: india
Member: 1555845 Status: Offline Sonork: 100.1604818 Thanks Meter: 4 | Quote:
05-27-2011, 07:28 | #23 (permalink) | |
Member: 1562047 Status: Offline Sonork: cas'per Thanks Meter: 0 | Quote:
05-27-2011, 07:40 | #25 (permalink) |
Freak Poster Join Date: Jul 2009 Location: .::Proud To Be A Muslim::.
Member: 1068814 Status: Offline Sonork: 100.1584449 Thanks Meter: 10 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:5/26/2011 6:21:53 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 00000 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-4636A64D01270075 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:6:22:08 PM ---------- |
05-27-2011, 07:48 | #26 (permalink) |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | UFS HWK Update SUCCESS ......... UFS HWK Update SUCCESS ...... Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:5/27/2011 12:15:12 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 12345 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-12121212121212A -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:12:15:23 PM ---------- |
The Following User Says Thank You to Arshu007 For This Useful Post: |
05-27-2011, 08:17 | #27 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1434428 Status: Offline Sonork: nonunikku18 Thanks Meter: 1 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:5/26/2011 10:45:10 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 99585 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-FB4D5529002700C8 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Connection to server failed: Socket Error # 10060 Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.) this is my problem pls help me.................. |
05-27-2011, 08:27 | #28 (permalink) | |
Member: 1434428 Status: Offline Sonork: nonunikku18 Thanks Meter: 1 | Quote:
The Following User Says Thank You to nonunikku18 For This Useful Post: |
05-27-2011, 10:31 | #29 (permalink) |
No Life Poster Join Date: Feb 2010 Location: sri lanka
Member: 1235816 Status: Offline Thanks Meter: 95 | download support suite setup v2 HWK_Support_Suite_Setup_v02.02.000 - 4shared.com download free update your hwk |
The Following 2 Users Say Thank You to yuresh For This Useful Post: |
05-27-2011, 20:59 | #30 (permalink) |
Junior Member Join Date: Mar 2010 Location: FATEHPUR UP INDIA Age: 45
Member: 1248310 Status: Offline Sonork: 100.1641641 Thanks Meter: 7 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:5/24/2011 5:51:33 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 1234567 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-E36A276543600050 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:5:51:55 PM ---------- |
6110 Software Change/Upgrade??? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-17-2000 08:33 |
How to upgrade firmware on Nokia | Pepek | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-18-2000 23:29 |
Upgrade 5110 to 6110? | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 19:59 |
